Knocking /clunking sound when i apply the brakes
Old 08-26-2010, 10:48 PM
bob1's Avatar
Hello everyone- I hope you have some ideas for my problem. When I step on the brakes, I hear a knock or a clunk coming from the front end. It doesn't happen each time though. Any ideas what may be causing this? A bad bushing perhaps? Thanks.
Old 08-27-2010, 07:33 AM
TXGSXR1K's Avatar
is it comming from the brake pedal maybe? sounds dumb but thats where mine is.
Old 08-27-2010, 09:55 AM
bob1's Avatar
If i had to take a guess, it sounds like its coming from the front end. I'll ask my friend to stand outside the truck and listen for the location.
Old 08-27-2010, 10:30 PM
AZFX4's Avatar
Is it only while you are driving? Moving forward?
Old 08-29-2010, 06:38 PM
bob1's Avatar
Yes. I only hear it when i'm moving forward and applying the brakes, although not everytime i hit the brakes. It doesn't make any sound when the brakes are not applied.
Old 09-03-2010, 04:55 PM
saserby's Avatar
Hey Bob, any luck? Not trying to hijack this thread, but I put new brakes on the front and a couple weeks later started to notice a clunking/rattling up front whenever I hit a bump. Took me a couple weeks to realize I don't hear it when applying the brakes. Also, when I apply the brake, I hear one clunk/ rattle coming from the same area. Sounds like it's coming from the wheels. I think we have a similar problem. Mine is driving me nuts.
Anyone have any ideas?
Old 09-03-2010, 05:35 PM
bob1's Avatar
I haven't had a chance to check the problem yet- too busy with work and school. Hopefully in the next two weeks, i'll have time.
Old 09-24-2010, 11:19 AM
bob1's Avatar
I found the cause of the clunking and knocking noise- Bad, right upper ball joint, loose right brake mounting bracket caliper, and loose left lower control arm.
Old 09-24-2010, 04:35 PM
Ideal150's Avatar
Gottacheck mine, I did my brakes not too long ago and having the same issue. Gonna check them this weekend hopefully.
Old 09-24-2010, 06:40 PM
Derrick@TireRack's Avatar
Former Sponsor
Is this a clunk or does it sound more like a your dragging a logging chain?
Derrick
Old 09-24-2010, 08:22 PM
Ideal150's Avatar
a clunk
Old 09-27-2010, 08:13 AM
Former Sponsor
Not really sure. Might want to make sure there is not a loose caliper.
Derrick
Old 09-28-2010, 02:36 AM
Ideal150's Avatar
Well turns out it WAS the caliper. Found out the hard way.... Went out to hit a few trails sunday afternoon and was suddenly cut short when the front passenger caliper lost the bottom screw causing the caliper to swing out and lock up the wheel.... i was s******* bricks at first thinking maybe i had busted a hub or something... Well thanks for the help Derrick!
Old 09-28-2010, 08:30 AM
Former Sponsor
No problem. Hope there wasn't to much damage.
Quick Reply: Knocking /clunking sound when i apply the brakes
