Sponsored by: DashLynx
Fixing a wind noise problem.
Old 08-28-2010, 11:01 AM
twenty_over's Avatar
What are the chances of the dealer actually trouble shooting and fixing a wind noise problem that I have in my 2010 Ford Super Crew. I have tried to determine exactly where it’s coming from by taping up the door seems and the outer edge of the windshield and then going for a drive down the highway but I still can’t figure out where it’s coming from. It’s a whistling sound that I can hear clearly while driving down the highway with the radio off.
I’m open to suggestions.
Thanks,
twenty_over
Old 08-28-2010, 12:32 PM
CometFlash's Avatar
Do you have a bugshield or vent visors? On the '09+ those things can really make a racket.
Old 08-28-2010, 02:26 PM
jetech00001's Avatar
well you have to hear it a specific area if its on the passenger side have somebody listen from were its coming from . what mirrors do you have i get wind noise every once in a while it depends which way the wind is blowing . i have the towing mirrors and have you checked you door seal
Old 08-28-2010, 04:15 PM
Yes, I do have both. It wasn't problem with my 2001, but I know that since this truck is a different design it could be the problem, I'll have to experiment more.
Thanks.
Old 08-28-2010, 04:21 PM
I have the standard mirrors, not the towing type. It sounds like it's coming from the windshield but I ruled that out. As far as the area of the noise I'd say driver’s side. I did look around the firewall area but didn’t see anything amiss. I'll keep searching for the source and if I find it I'll post.
Thanks.
Old 08-28-2010, 04:35 PM
johnwill's Avatar
Thanks.
Remove the bug shield and see what happens . . .
Your 2001 has no relevance.
Old 08-28-2010, 05:54 PM
BIG_ole_TRUCK's Avatar
Or just have the radio playing, if it's only a small whistling noise.
Old 03-26-2011, 08:35 PM
Jim'sF150's Avatar
Big ole Truck -
Did you ever get your wind noise issue fixed? Curious because I just bought a used 2010 Super Crew and have a similar issue.
Old 06-30-2011, 03:58 PM
dryflysport's Avatar
I have the same problem with my 2010 F250 as well. It is coming from the drivers side but can't pin point the exact location. No bug shield or vent visor.
Drives me crazy. seems to only happen a highway speed and when it is very windy out side??
Old 06-30-2011, 07:31 PM
FYI, I determined that the wind noise was in fact caused by the shield. I have not changed or removed it because I really like the way it looks, but in a few years when it most likely fades I will buy another brand.
Good luck to you other folks who are trying to solve your wind noise problems.
twenty_over
Old 06-30-2011, 09:28 PM
bansheerider's Avatar
twenty_over
What brand bugshield do you have? I was thinking about getting one.
Old 07-01-2011, 08:32 AM
Joe_STX's Avatar
I have the same exact problem with my 2010 Screw. I only hear the whistling at 65 mph or above and not consistently. I never noticed this until after I put on the bugshield. So I am assuming the bugshield is the culprit.
Old 07-01-2011, 08:34 AM
Joe_STX's Avatar
OH! and by the way, "DO NOT LET THE DEALERSHIP TOUCH YOUR TRUCK UNLESS ABSOLUTELY NECESSARY." They will screw up it up more.
Old 07-01-2011, 03:06 PM
I have the AVS Bug Shield (http://www.streetsideauto.com/p/auto...flector-23009/). It looks great but next time around I will try another brand, I think Ford makes one so maybe I'll go that route.
I figured out that it was the shield by taping up the gap between the hood and the shield with wide blue painters tape and took it for a ride down the highway, with the gap all sealed up the wind noise had stopped.
best of luck to ya,
twenty_over
Old 10-19-2011, 04:29 PM
egra2010's Avatar
Unhappy The wind noise is driving me crazy.
My 2010 F-150 Super cab has a terrible wind noise coming from the windshield in the middle but a little towards the passenger side. The dealer had a windshield company take it out and reseal it. It made it a little better for awhile but is now getting worse. It is a hissing noise. I do have a factory installed bug shield.
Quick Reply: Fixing a wind noise problem.
