Help with rear axle seal replacement procedures
https://www.f150online.com/forums/ar...lots-pics.html
this is the procedure i used. it's all basically the same.
the axle seal leak is fairly common amongst all 97-up f150s.
if it is a small leak, let it ride unless it's just bugging you. as long as the seal doesn't completely let go you'll be able to ride on it for quite some time. check the gear oil every oil change and make sure the leak doesn't get worse.
it is always a good idea to change the seal whenever you get the time though. i rode on mine for a little over a year and it went on me 20 miles from home. i limped it home but ended up having to replace an axle. my axle tube still isn't right either.
