Oil Dipstick Tube Replacement
Old 09-18-2010, 01:51 AM
alschmid's Avatar
My dipstick tube rusted and broke. I have a new dipstick tube from ford for my 1997 ford 5.4. Can the tube be installed without removing the stock manifold. It appears to be not sliding down between the manifold and block freely.
Old 09-18-2010, 03:49 AM
Klitch's Avatar
2 things hold it in, 1 bolt midway on block, and that dried up o-ring will be a bear. Yes you can replace it without fiddling with anything else.
good luck!
Old 09-18-2010, 03:58 AM
alschmid's Avatar
The old dipstick tube is removed. I tried to push the new tube from the top of the engine through the opening in the exhaust manifold and the bend in the tube prevented it from going through. I didn't want to force it and end up with another broken dipstick tube. Is there any special way to feed it through the opening in the manifold?
Old 09-18-2010, 11:09 AM
98f150guy's Avatar
I had the same problem with my 98. I ended up cutting the dipstick tube with a pipe cutter down by the manifold, putting the piece in that goes into the pan and then connecting the top part with a thick piece of rubber tubing. Held the whole thing together with hose clamps. It's been 2 years now. Still holding up. Can be a pita to get the dipstick back in sometimes though because the two parts of the tube aren't perfectly lined up. But it saved me the trouble of having to remove the exhaust manifold.
Old 09-18-2010, 03:13 PM
Bluegrass's Avatar
Up on replacing my tube on a 4.6, I found the tube too long to get in place without cutting about 1" off the bottom of the tube.
There is about 3" +/- below the seal flange to work with.
You need the tube and stick to be air tight because the crankcase is part of the detection system and may set a code if the crankcase closed system has a leak to the outside.
Good luck.
Old 09-18-2010, 10:35 PM
alschmid's Avatar
I got it to work. I had to cut off the bolt mounting bracket and force it from the bottom up (had to also remove the fender well). I may try to jb weld the mounting bracket on, but it is not going anywhere. I also had to use a prybar to slightly bend the tube to fit into the oil hole in the block.
Old 05-01-2015, 10:33 PM
MercuryMudSling's Avatar
Thanks for the great advice!
I put the new tube in about as far as it would go without force. It was below the opening and beyond it. I measured the extra length and removed the tube and cut off the 'extra' - about 3/4 inch. This allowed me to get back into place and push it (see 'bend') so the end would now enter the opening.
Then it was just a matter of applying force to get it to seat flush. My wife used a 2 ft 3/4 extension applied to the bracket and a hammer from above while I worked it from below. It seated in no time - compared to the hours some of you suffered doing this project.
It's in. It's all scratched up and not pretty, but it works.
2003 F150 Supercrew Styleside, 4.6L
Old 11-23-2015, 11:47 AM
av-carl's Avatar
I have a question maybe someone can answer, I was in the process of changing the exhaust manifolds the left was so rusted I had to cut it in pieces with an angle grinder to cut the nuts off the studs, in doing so I accidentally cut the dip stick tube off. I had one hell of a time pulling the old tube out, finally it came out. But the end part stayed in the block I tried an easy out it wouldn't grip so I whacked to with a hammer and instead of gripping the piece it fell into the pan. I have not been able to fish it out. My question is does anyone know if it will cause a problem if I leave it in the pan???
Old 11-23-2015, 05:02 PM
Bluegrass's Avatar
My feeling is it will fall to the bottom of the pan and stay there and not be an issue.
More important is the dirt and filings that could get into the oil pump and cause wear.
So change the oil at the least and take a chance, otherwise drop the pan far enough to get it with a spring loaded long grabber or a magnetic extension.
You won't get it back out of the hole in the block..
Good luck.
Old 11-23-2015, 06:26 PM
av-carl's Avatar
Piece of the dipstick tube in the oil pan
Thanks for the advice, if I can drop the pan a little will the gasket reseal?
Old 11-24-2015, 11:17 AM
grizzstang's Avatar
Nope. You will require a new gasket. I have not done an oil pan gasket on my truck but I have done them on other vehicles and they are a PITA to do.
It should fit through the drain plug hole unless it is really mangled. I would try to fish it out through there first. Maybe rent a bore scope and see if it even made it down to the oil pan.
Quick Reply: Oil Dipstick Tube Replacement
