If I swap steering columns, must I swap ignition keys?
Old 11-07-2010, 12:48 AM
garyherring's Avatar
I just purchased a 97 Expedition with about a half inch of play in all directions in the steering wheel. The airbag light is not on, but cruise control does not work. I pulled the airbag and the wheel/torx screw is tight on the shaft, so from reading the threads on steering columns (thank you guys - very educational, specail thanks to Steve83) I assume the housing assembly that holds the bearing below the wheel is either worn out or broke. There is a used column at the salvage yard and perhaps the problem will not warrant that once I pull the wheel and see what is actually broke - BUT assuming worst case and it is cheaper or easier to replace the entire column could I use my existing keyset in the new column? Between the anti-theft key fob and autostart, I am leery of creating a new set of problems to solve the existing one. Any guidance would be most appreciated.
Old 11-07-2010, 10:50 AM
SSCULLY's Avatar
the 1997 Expedition has a PATS key ?
Does it look like this :
The F-150 introduced the PATS key with the digital odometer in 1999. The Expy had changes that were sooner on some items, this is why I ask.
The EXPY should be the same ( I cannot say 100% it is ) that the PATS info is stored in the HEC in the cluster. It is easy enough to pull the key cylinder, to get it in the new steering wheel column
Post #10, JMC describes how to remove the key cylinder in this thread ( on a F-150 )
https://www.f150online.com/forums/el...beep-beep.html
Old 11-07-2010, 03:29 PM
Yes I have a PATS key with a chip in it that looks very similar to the above, and how to program more keys (up to 16) is in the Owners manual that came with the vehicle. What I didn't (don't) know was what the "chip in the key" talked to and where it was located or how it actually works. The forum educated me on replacing the column and how to pull a key cylinder, but I could see myself with a new column that doesn't wiggle, but a truck that wouldn't start if the Key chip talked to a corresponding reciever (that wasn't changed) in the new column.
Old 11-07-2010, 04:12 PM
projectSHO89's Avatar
There is nothing in the steering column that would require a new key provided you transfer the ignition cylinder.
The PATS system uses a ring around the key cylinder that is the antenna for the key reading process. As long as the replacement column has the antenna ring or you transfer the old one over, there's no problem.
IIRC, the 97 Expy & Navi were the first of Ford's trucks to get PATS (several high-end cars had it in 96). A separate PATS module was used until sometime in 98 or 99, at which time the PATS was integrated into the HEC and the PCM.
Old 11-07-2010, 06:02 PM
Thank you very much - a new column with a transferred ignition cylinder is in my near future. The new column is from a 98 Exp so I will ensure it has the antenna ring identical to what is in my 97.
Quick Reply: If I swap steering columns, must I swap ignition keys?
