Transmission Service? How many quarts?
Old 11-10-2010, 12:28 PM
ranger332's Avatar
Exclamation Transmission Service? How many quarts?
What exactly do I need for a trans. serv. on an 2005 F150 5.4.
Do I need 14 qts of fluid (the entire refill capacity) or less, does it all get changed in a pan drop or does most of the fluid stay in being the torque converter doesnt have a drain plug. I know that I need a trans filter kit. Just wondering how much fluid for a pan drop service. Please advise. Thank You.
Old 11-10-2010, 01:03 PM
MGDfan's Avatar
Hi.
Approx 5-6 quarts, and always check the level as per the manual - add until it''s correct.
MGD
Old 11-10-2010, 06:48 PM
F-150-2's Avatar
I usually do the procedure where you disconnect a line at the trans cooler after the pan is back on and pump out the remainder a few quarts at a time. Pump/fill and repeat. Gets you pretty close to 100% fluid change that way.
Old 11-10-2010, 10:46 PM
MotoMike's Avatar
Originally Posted by MGDfan
Hi.
MGD
Mine was right at 5.5 qts when I did mine. Mercon V.
Old 11-14-2010, 02:24 PM
4wd150's Avatar
i need to do mine sometime in the near future as well. so drop the pan, change filter, then just add 5 quarts or so back in?
Old 11-14-2010, 05:47 PM
Yes, if all you are doing is a pan drop. However, your 2000 should have a torque converter drain plug, so I'd drain that too. You will need about 14 quarts.
Old 11-14-2010, 06:06 PM
4wd150's Avatar
alright cool thanks
Old 11-15-2010, 05:42 PM
BlueOvalFitter's Avatar
Cool
This is my 3rd F150 with the AOD/4R70W/4R75E type transmission.EVERY one of them that I have dropped the pan on and did a filter/fluid change only held 4 QUARTS of transmission fluid! The dipstick always reads less then half way into the cross hatched area!
Old 12-06-2010, 12:45 PM
m_melen's Avatar
Im ready to do a trans flush on mine, any recommendations on a brand of trans fluid? I just dd my truck with very occasional towing.
Old 12-06-2010, 01:05 PM
IR0NS1N's Avatar
I use AMSOIL trans fluid myself. When you drop the pan and change the filter it should be about 5-7 quarts mine took 7 I believe. If you can drain the converter (cant on my truck) You'll be close to 14 qts.
Old 12-06-2010, 01:25 PM
str8t six's Avatar
i use valvoline trans fluid.
Old 12-06-2010, 02:33 PM
Thumbs up
I use either Motorcraft or Castrol MerconV.
Old 12-07-2010, 07:42 PM
m_melen's Avatar
i'm using a fluid exchange machine that i can use while the engine is running so i can flush the stuff in the converter too
Quick Reply: Transmission Service? How many quarts?
