How to fix automatic radio shut off, interior light on/off etc
Old 11-26-2010, 11:21 AM
mlawdawg's Avatar
Recently, my automatic functions stopped working. So the light does not come on/shut off automatically when i turn the truck off. Teh radio will keep running if I do not manually shut it off. The auto lock do not work. Etc. The Info center controls do not allow me to adjust--message says sometingl ike default in system or something. Any clues? Thx
Old 11-26-2010, 12:55 PM
J.Wal's Avatar
I had a place install a radio/ amp in my old 06 F150 and somehow they made it where my radio wouldn't cut off. I took it to the ford dealer and they said a fuse had blown and they replaced it, and never had the problem again. I thought it was a odd fix but thats what they said!
I am not sure which fuse it was though
Old 11-26-2010, 01:38 PM
mlawdawg's Avatar
I wondered if it could be a fuse. Hope so, as that is a cheap, easy fix.
Old 11-26-2010, 01:45 PM
Stu486's Avatar
...do any of the power options in the drivers do work? Check the ground in the door, see if its good. Also there is a thread about a similar problem with the wiring in the door sills. I'll look and see what I come up with for ya...
Old 11-26-2010, 01:52 PM
Stu486's Avatar
------>THIS MAY BE YOUR ANSWER<------
read through this post, it has been a very common issue. hope this helps, good luck
Old 11-26-2010, 01:56 PM
mlawdawg's Avatar
Thanks. Yes, the power controls (p/l, p/w)) work fine
Old 11-26-2010, 02:02 PM
mlawdawg's Avatar
Good read. Hopefully it will be a fuse--seems much simpler to address.
Quick Reply: How to fix automatic radio shut off, interior light on/off etc
