Royal Purple ATF
Old 12-09-2010, 02:38 PM
damiansalmond's Avatar
Royal Purple ATF
It's about that time on my truck to give it a tranny flush. I want to change the fluid type to Royal purple, but I have heard some rumor that it is not good in ford trucks. I do some towing with my truck, but when I do its a heavy load, otherwise, it is just normal driving (with a lead foot I would add) So, what I am asking is it safe to put royal purple ATF in the transmission?
2007 FX2 F150, 5.4 V8, K&N cold air intake, more to come...
Old 12-09-2010, 02:46 PM
glc is online now
I'd recommend Amsoil instead.
Darrin Burch recommends Mobil 1.
Old 12-09-2010, 02:52 PM
FX4life's Avatar
The only place I use RP is in the differentials, in my opinion RP is overpriced even for the differential oil... I just use the valvoline ATF recommended by ford for my trans flush.
Old 12-09-2010, 02:58 PM
bankrpt's Avatar
I just switched my engine oil and filter to Amsoil monday. I will be switching my trans fluid to Amsoil when I do my trans service next.
Old 12-09-2010, 03:08 PM
LightningJMP's Avatar
I run RP in my diffs and engine now and will soon be making the switch to RP in the tranny and transfer case as well. I think its all just matter of opinion, I don't think you can go wrong using Amsoil, Mobil 1, or any other quality brand.
Old 12-09-2010, 03:14 PM
My preferences....
Motorcraft
Amsoil
Mobile1
Old 12-09-2010, 06:07 PM
thanks
Thanks for your opinions. I really believe rp is the best, abeit overpriced, but you get what you pay for. I never liked mobile one after I seen the royal purple salesman take a bottle of it off the shelf and put it to shame. Again thank you and keep the opinions coming!
Old 12-09-2010, 08:10 PM
SuperSlabCab's Avatar
I buy all my Royal Purple on Ebay. 5 gallon 5w-20, and quart-case Trans Fluid.
I flushed the Mercon V out two months ago, and did something like 18 quarts to refill...I've got a Mag-Hytec DD pan, and an auxiliary spin-on trans filter.
The truck already has a separator plate-but even so, it shifts better now, over the Mercon V.
The motor oil is the best I've ever used. I burn NO oil.
I also run RP in my motorcycles.
I'm pretty sold.
Old 12-09-2010, 08:43 PM
avfrog's Avatar
Royal purple is great oil, but I don't think it is worth the extra cash.
Old 12-10-2010, 05:35 AM
Fifty150's Avatar
Royal Purple works fine in Ford. So does Red Line & Lucas Oil. Red Line has a "High Temperature" formulation that I like.
Old 12-10-2010, 05:36 AM
Fifty150's Avatar
Which auxiliary filter do you have? Where did you install it?
Old 12-10-2010, 08:50 AM
I bought my filter from Dieselsite.com, although I don't see it listed there anymore. It uses a large spin-on, and its mounted up by the trans cooler.
Filters, but is also directly in-line to catch debris, should the trans blow up, from entering the torque converter.
It has a gauge that tells you when flow is restricted, and the filter needs to be changed-which has never happened.
Old 12-10-2010, 09:03 AM
Galaxy's Avatar
Amsoil...nothing but in all applications. Their Severe Gear I arguably the absolute best you can get. Their ATF will perform flawlessly in your tranny.
Old 04-13-2011, 05:17 PM
HamboneFX4's Avatar
How is it overpriced if it can go 6000k???
At 3000k you change the filter and add a quart!
Quick Reply: Royal Purple ATF
