What are the biggest tires i could fit on my f150?
Old 12-27-2010, 10:23 PM
whitelightning5's Avatar
I've got a 2002 F150 4x2 regular cab with a 2inch level. What are the biggest tires i could fit on the stock rims without rubbing? Please post some pictures to help me out.
Old 12-27-2010, 11:44 PM
speedyturtle's Avatar
probably 33's. Id say thats the largest id go since its a 2wd.
Old 12-28-2010, 01:08 AM
Would 33's rub at all?
Old 12-28-2010, 01:14 AM
offroadn'98's Avatar
A 295/75-16 about a 34 pretty stuffed looking can't remember if he said he had rubbing. I don't think he did, or not much
Old 12-28-2010, 01:35 AM
Buxton91's Avatar
i have no experience with a 295. but 285's fit perfect and 305's will fit but will rub the sway bar at full steering lock.
Old 12-28-2010, 02:41 AM
A 295/75r16 is taller but thinner than a 305/70r16. I think it looks pretty cool on a 2wd but once again can't remember where or if it rubs..
Old 12-28-2010, 02:50 AM
It was a member, lil bizzy..
295 bfg ko's he prob has some threads about fitment if you wanna do some searching
Goodluck
It's not a 4wd ignore the stickers
Old 12-31-2010, 03:13 PM
what size in inchs are 295s?
Old 12-31-2010, 10:59 PM
wandell's Avatar
Remember, he has a 4x2, not a 4x4. The 4x2's sit 2 inches lower. A lot depends on the wheel width and backspacing you use. With the OEM wheels or an aftermarket 8 inch wide wheel with 4.5 inches of backspacing you can fit 285/75-16's/ 185/70-17's (33x11.50) easily.
Also, a 295/75-16 and 295/70-17 are essentially 34x12.00 tires. You will need a little more lift to fit them on your leveled 4x2.
Old 01-02-2011, 02:53 AM
Lil Bizzy's is a 2wd, it just has 4wd stickers.
Old 01-03-2011, 08:55 AM
BLUE20004X4's Avatar
I've seen 265/70/17 on and they look good, if 285/70/17's fit, definetely go that route!!!! Provided you have 17" rims
Old 01-03-2011, 04:49 PM
I've got the stock 16 inch rims on it
Old 01-04-2011, 12:09 AM
285/75-16
Quick Reply: What are the biggest tires i could fit on my f150?
