Looking for replacement cab corners for 04 S-Crew
Old 12-30-2010, 11:12 AM
89TRX350RX's Avatar
I've looked everywhere I can think of, and can't seem to find a listing for replacement rear cab corners for my 04 S-Crew. I have rust that is slowly coming through from the back side... I took it to my body man and asked him to repaint the grey around the bottom of the truck, and to repair the corners... He looked into finding them through his sources and the only thing he could find was for $1200 and i think it was a whole side repair panel... Any help would be great?!?! I don't want to have it repaired only to come out agian in another couple of years... would prefer to replace them with New Steel...
Are there any online car recyclers that may be able to get from a southern wrecked truck???
Thanks in advance, Jamie
Old 01-04-2011, 02:42 PM
djb25's Avatar
Any idea what caused your cab corners to rust out in the first place?
I'm having the same problem and I don't know where the problem is coming from. I've already had them repaired once...
- Damion
Old 01-04-2011, 02:45 PM
SoonerTruck's Avatar
My guess would be a leaking glass or 3rd brake light.
Old 01-04-2011, 02:47 PM
djb25's Avatar
I'm going to check the third brake light tonight. That might be the issue.
- Damion
Old 01-05-2011, 10:07 AM
89TRX350RX's Avatar
- Damion
I have not had a chance to look, but the 3rd brake light will be the first thing i look at... Still cannot find replacement corners...
Old 01-05-2011, 01:56 PM
Well normally when the 3rd brakelight goes, you notice the headliner stains before you get rust. I can't imagine it being anything other than the back windows though.
Old 03-07-2011, 01:34 PM
Impact9's Avatar
Bump! I need to replace my right cab corner, rock nailed it and it's got a deep case of rustitust. I rather cut out and replace if anyone knows where to get this new steel at.
Old 04-11-2011, 01:18 PM
renaud's Avatar
Bump.
Anybody have any luck here? Just noticed both of my rear cab corners have little bubbles in the paint. Would like to take care of it before it spreads.
Old 07-30-2011, 09:20 AM
Impact9's Avatar
No luck even with online junk yards. Might have to go visit a few local places to see if they will let me cut into a cab. I cut the the visible rust out but there is rust way up inside the corner between the inside and outside skin where I can't get. It's just a matter of time before this become a serious issue. I'll probably be cutting the insides out to get to the rust this fall.
Old 07-30-2011, 03:34 PM
StoveTop's Avatar
Previous poster was in April so in case "renaud" is still interested, I suggest LMC Truck for stuff like this.
Old 08-09-2011, 12:59 AM
blackedout50's Avatar
Same thing is happening to my 2004 s-crew... it is a common problem. water is coming in from where the cab corner meets back wall of cab. There is a large hole where the panels are joined that lets water that kicks up from the tires collect and rust the cab corners inside out. Due to the fact that is has no where to go. I wish i would of found this hole when i bought the truck and sealed it. I found a great website I plan on ordering my replacement cab corners and probably a rocker panel too.
http://www.fixmyrust.com/2004-2008-f...crew--AHK.html
Good luck, Hope this helps
Old 06-17-2012, 02:59 PM
89TRX350RX's Avatar
Just got a body shop to replace my corners and rockers... repainted the Grey all around my truck including the bumpers... Looks awesome... I will post pics when I can... And Blackedout50.... thanks for the link
Quick Reply: Looking for replacement cab corners for 04 S-Crew
