howling noise?
Old 01-04-2011, 07:00 PM
mcline86's Avatar
howling noise?
My trucks making a weird howling noise, usually happens at any cruising speed and acceleration it will get a little louder. If i let off the gas it goes away. To me the sound seems to be comming from under the cab....its pretty loud sometimes. any ideas?
Old 01-04-2011, 08:29 PM
Red02FX4's Avatar
Check for a wolf hanging on for dear life
Beginnings of an exhaust leak??
Old 01-04-2011, 09:39 PM
Toyz's Avatar
How many miles on the differential fluid?
Old 01-05-2011, 07:03 PM
mcline86's Avatar
lol only wolf hangin on there is me, it already has a nice loud exhaust leak lol....
not sure how many miles on the Diff fluid we bought it used. it has 170k miles tho on the truck. dunno if this makes any difference but just noticed today that when going from drive to reverse it makes a pretty big clunk noise, and if u go back to drive from reverse it does it again but not as loud......i feel like this truck is about to to **** the bed......
Old 01-05-2011, 08:03 PM
Toyz's Avatar
Check the U joints for any play. I would change the rear diff fluid out. If it is a LS differential, its probably due for a change along with friction modifier. You can check the rear axle tag
Old 01-05-2011, 08:14 PM
Red02FX4's Avatar
also block the wheels, put trans in neutral and try to turn the driveshaft to check for play in differential. Definitely change the gear oil / modifier
Glad you have a sense of humor....... couldn't resist that one
Old 01-06-2011, 06:59 AM
enriched's Avatar
Also check the rear mount on the tranny...they can separate...giving the "1 click and done "...when going from F to R & vise-versa. It could take out the U joints as well.
the howl...yeah, agreed, change the Diff fluid
Old 01-06-2011, 10:29 AM
BLUE20004X4's Avatar
If it's only while driving, sounds like the rear end maybe. If it's around 1500-2200 rpm's, a/c compressor is to blame I strongly believe.
Old 01-06-2011, 10:33 AM
b2therad's Avatar
Friction modifier man. I had that same problem. It would appear around 40mph and wouldnt go away till like 55.
Old 01-07-2011, 05:31 PM
mcline86's Avatar
il hafta change that out....well see if it fixes it thanks yalllllll
Old 01-07-2011, 06:14 PM
aaron1998f150's Avatar
check the differential cross it proboly needs changing or the oil in the diferrential are u sure its comming from under the cab
Old 01-07-2011, 07:23 PM
Toyz's Avatar
While our doing that, lemme drive that CTS I promise I'll be nice
Quick Reply: howling noise?
