1995 F-150 Wiring Diagram?
Old 01-21-2011, 05:12 PM
PAINTER78's Avatar
Anyone have a 1995 F-150 wiring diagram? I have the Clifton book with the wiring diagrams but its very vage, poorly designed, and not complete. Please help!
Old 01-21-2011, 07:05 PM
projectSHO89's Avatar
ebay...
Old 01-22-2011, 01:07 AM
Steve83's Avatar
Never heard of Clifton - do you mean Chilton's? Is it similar to this?
What exactly are you looking for? Read these captions:
Old 01-24-2011, 05:41 PM
PAINTER78's Avatar
I can't spell, thats what I meant.
I meant Clifton. I want to look at the fuel pump, fuel display, fuel guages, and dual tank switch. I need to know where to wire it/color wire to cut/wire size.
Old 01-24-2011, 05:56 PM
PAINTER78's Avatar
Chilton! I got it in my head that it's a Clifton.
Old 01-25-2011, 12:03 AM
Steve83's Avatar
Why are you cutting fuel pump & gauge wires? Click my black Bronco in my signature & read the captions in the '90-96 Fuel System album.
Old 01-31-2011, 05:52 PM
PAINTER78's Avatar
I want to install a kill switch. Someone suggested to cut the fuel pump positive wire. Where would be the best place to install one? Any clue on were to find a good wiring diagram? The Ford website only goes back to 96.
Old 02-01-2011, 11:11 AM
Steve83's Avatar
There's already a factory kill switch in the fuel pump circuit - it's called the "Inertia Fuel Shutoff (IFS) switch" and it's inside the R kick panel just below the glove box. If you cut the notch in the panel ~1" lower, you'll be able to pop the button up without removing the panel each time. Did you read those captions? The IFS is near the bottom of that album.
And I already told you where to get the wiring diagrams, in my first post in this thread. That FleetFord link is part of projectSHO's signature - it wasn't part of his reply to you; it appears under all his posts. But you probably don't need any diagrams for this. If you still want to add a switch, check this out:
Old 02-07-2011, 04:40 PM
PAINTER78's Avatar
Thanks man, I didn't ever realize the wiring diagram was in your first thread. I will go check out my eye sight out tommorow. I am going to run it in series with the IFS switch.
Old 02-07-2011, 05:28 PM
Steve83's Avatar
You're asking for trouble cutting into that circuit. Just trip the IFS when you want the truck disabled. It's even in your owner's manual as preparation for changing the fuel filter.
Old 02-07-2011, 05:54 PM
PAINTER78's Avatar
Hi
Won't notching it or cutting a hole in a panaling be obvious? I would like to add a kill switch to kill the fuel system. Where would u add it to the fuel system? In series would work, right?
Old 02-09-2011, 06:51 PM
cwthill's Avatar
hey i got a 95 wiring harness at a local salvage ,we swapped it out in about 1 1/2 hours and the truck is shifting great running smooth. i still have to add a overdrive light and switch but getting closer to completing the swap over thanks for the diagrams and information. concerning the fuel cut off switch if you are wanting to use this as a security system or anti theft device . its probably better to put a loop and switch in your ignition relay power wire, this will disable the vehicle when switch is off and allow normal operation with the switch on. I've seen a few done this way back years ago and i don't think it would create any other major problems.
Old 02-10-2011, 02:31 PM
Steve83's Avatar
No, it's under the dash. Have you looked at yours yet?
You're asking about adding a switch to a circuit that already has a switch that does exactly what you're trying to do. It's like trying to add a switch to make the horn blow - there's ALREADY ONE to do that. Chop up your wiring if you want.
Quick Reply: 1995 F-150 Wiring Diagram?
