Knock sensor cause engine failure?
Old 02-14-2011, 10:17 AM
austinbF150's Avatar
I recently had to replace the motor in my 2004 5.4. It ran good for about a week after I got it back and then I got a knock sensor code and it is running just like it did before it blew. I don't know how much the sensors control so I was wondering if this sensor could have been my problem all along causing the failure of my last motor? I never got a code before my last motor blew but I know that doesn't mean there couldn't have been a problem
Old 02-14-2011, 10:58 AM
jbrew's Avatar
Post the DTC.
Old 02-14-2011, 12:28 PM
P0325
Old 02-14-2011, 12:39 PM
MGDfan's Avatar
A start?
https://www.f150online.com/forums/20...0325-code.html
AFAIK - a faulty KS1 or KS2 will not directly grenade an engine - if anything you'll simply lose power as the PCM thinks detonation is occurring and agressively pulls timing.
But - if NO signal is being generated AND an actual condition IS causing severe detonation, then over time it could be cause for concern, because the PCM ISN'T reacting as it should to negate it. But this assumes there is another pre-existing condition that is causing the detonation - it's not the KS's fault in and of itself - you just lost the instrumentation.
Good luck - Jbrew's on the case
MGD
Old 02-14-2011, 12:51 PM
Ok that helps. I'm hoping this is an unrelated issue and all will be well after the sensor is replaced. I had the problem for months and the truck spent a lot of time at the dealer without them being able to figure out the problem before it finally blew. Being that I have a new motor is there something that wasn't replaced that could cause this besides just a faulty sensor? Thanks for the help guys, I just don't want to end up in the same situation that I was 3 months ago after spending thousands on the repairs
Old 02-14-2011, 03:35 PM
jbrew's Avatar
Snake a magnet around the sensor, - make sure their isn't any tools pinned against , like a socket, extension, half a bologna sandwich, -you get the idea.
On the three valve, - they don't sit in the bottom of the valley. More like up on the shelf lol. I'll see if I can find a pic, - you might have two ??? Hang on.
Old 02-14-2011, 03:40 PM
jbrew's Avatar
Old 02-14-2011, 04:09 PM
jbrew's Avatar
Well, I haven't seen two knocks on the truck engines. - No that will not cause your motor to blow. If clear from foreign matter, you either have a bad sensor, short in the harness or a PCM problem. That's the 123. If you want further diagnostics info, specify procedure or spec info desired.
Old 02-14-2011, 04:20 PM
The dealer is supposed to be letting me know if the sensor is covered under the warranty from the motor replacement. Hopefully it will be and that will mean they have to fix it if its a short or faulty sensor. Im really hoping this is the issue, if not it may be that it was my pcm all along which is going to mean another pricey repair.
Old 02-14-2011, 06:41 PM
The dealer called back and want $375 to replace the sensor. Is there any way to tell that it is infact the sensor before spending that much? My dad has an 07 5.4 4x4, the same as my 04. Is it worth a try putting his pcm in my truck to see if this resolves the issue?
Old 02-14-2011, 06:51 PM
jethat's Avatar
if the dealer wants to do diagnosis via parts replacement get your truck out of there, The dealer service departments should be able to tell absolutely if thats the problem.
Old 02-14-2011, 07:53 PM
Thats what their computer says it is but there may be no way of knowing if its a problem with the pcm
Old 02-14-2011, 08:03 PM
piston91's Avatar
I would check the wiring harness for the knock sensor inspect it unplug the connector from the pcm and check it for continuity if it is open the computer will cause the engine to run like garbage. Im sure someone on here knows the pcm pin diagram and can tell you which pins to probe. If need be I can look it up for you tomorrow on alldata.
Old 02-14-2011, 08:36 PM
Thanks, Im going to talk to a friend of mine who is a ford mechanic about looking at it this week. Im in school so it will be this weekend before i can look at personally.
Old 02-24-2011, 02:16 PM
DopeFedLSX's Avatar
here's some ecm pinouts for the 04 f150
-Zach
F.I.S.T. Racing
knock sensor signal located here
Quick Reply: Knock sensor cause engine failure?
