How do you take off the interior door panel
Old 04-20-2011, 10:30 PM
larbec's Avatar
I want to change out my speakers. Can someone tell me how to remove my door panels in the front and rear in my 1998 F150 Extended cab? Picture would be great if someone has one
Old 04-20-2011, 10:46 PM
Buxton91's Avatar
You have to undo the bolt holding on the door handle and the one to the window crank if yours are manual. Then just slide the panel straight up and it should come out.
Old 04-20-2011, 10:58 PM
pizzaman711's Avatar
for the rears just pull the top section out, then look around the bottom part for any bolts or push in clips, undo those, then pull up and out.
Old 04-20-2011, 11:02 PM
jtwoodall's Avatar
Old 04-21-2011, 07:34 PM
larbec's Avatar
Thanks guys, the drawing is great and I have power windows. It is an XLT
Old 04-21-2011, 08:56 PM
kansasflareside's Avatar
The doors for the later models are quite different.
Fronts:
Pull of the small triangle panel on the inside, parallel to the mirror.
Take off the small circular piece just behind the door handle.
Insert a ratchet inside the hole to loosen the bolt holding the door handle on.
Pull door handle out.
Pop off the window/lock switch off by pushing up on the edge of it.
Disconnect all the plugs going to the switches so you can completely remove the switch panel.
Pull up, then out on the door panel.
Pull the panel out a few inches, then reach behind the panel and remove the marker light by turning the light a quarter turn, the pulling it out.
Rear:
Remove two bolts holding on the lock for the vent window.
Pull out on the top panel to remove it.
Remove pins on top of bottom panel by gently pushing in on the center of the pins with a small phillips head screw driver.
Pull up, then out with panel.
Hope this helps. Be patient and try hard not to break anything.
Old 04-21-2011, 09:41 PM
larbec's Avatar
Mine is a 1998 model with power windows so which would I use? The one with the drawing link?
Old 04-21-2011, 10:06 PM
Where is your door handle? Above the arm rest, or below it?
Old 04-22-2011, 09:07 AM
larbec's Avatar
yes my door handle is above the arm rest
Old 04-23-2011, 10:59 PM
Oh, then that diagram is correct. Thought the 97's and 98's were the same, but I guess only the 97's have different door panels. Ignore my instructions then.
Old 05-08-2011, 06:29 AM
projectXf150's Avatar
Thanks kansasflareside thats exactly the directions I was looking for. I have a 98 XLT and my handle is below the arm rest. Is it really as simple as you put it? I need to find my plug for the courtesy light it went missing somewhere inside the door panel
Quick Reply: How do you take off the interior door panel
