Cold Belt Noise
Old 05-11-2011, 02:30 PM
Jetpilot2's Avatar
Cold Belt Noise
Does anyone experience belt squeak when starting a cold engine? Mine makes quite a bit of noise until warm, then not a peep!!:o
Old 05-11-2011, 02:44 PM
FATHERFORD's Avatar
What belt are you running?
Is it humid?
How much slack is in your belt?
Old 05-11-2011, 03:49 PM
twinskrewd's Avatar
Mine does that. However the chirping is from the alternator bearing. Took me a while to figure that one out. Pissed me off to. It started with 42k on the truck.
Old 05-11-2011, 06:43 PM
IR0NS1N's Avatar
Never put belt dressing on a belt. Ruins the belt and the pullies and it a PITA to remove. A belt squeel on start up is because of a loose belt over an alternator. A bearing will make noise all the time from my experience.
Old 05-11-2011, 06:57 PM
Jetpilot2's Avatar
Is it humid?
It's the NAPA belt that came with the upgrade kit. I'm pretty sure there is not that much slack, putting the belt on is almost impossible.
I heard the NAPA belts are notorious for noise, so I just got a Dayco on the recommendation of someone who deals with these belts regularly and has dropped the NAPA belts due to the number of return customers complaining of belt noise. I will be putting it on, and will let you know in the morning.
The noise goes away when warm, so not sure about the alternator, but who knows; the alternator did come with the blower and I used it instead of my original one.
Old 05-11-2011, 08:52 PM
twinskrewd's Avatar
Not this one lol. Took the belt off and spun the alt by hand and could hear it. It will do it for about the first 3 mins of run time. Longer when it was cold out. I sprayed some Teflon lubricant on the bearing and it stopped for about a week. And yes belt dressings are bad news.
Old 05-12-2011, 06:27 AM
FATHERFORD's Avatar
Gates green stripe belts are the preferred belt of blowers.
Dayco's in the blower community are known as the worst...
Old 05-12-2011, 07:23 AM
Jetpilot2's Avatar
GREAT~!!!
Well, turns out, Jason was right; it's my alternator. I went to change out the belt this morning and when I spun the alternator, I heard the "squeak". I'm in the process of putting my original alternator back on now. I guess I'll leave the NAPA belt on in light of the above.
How did your school car show go? I know you're busy, but when you get a chance...
Old 05-12-2011, 07:25 AM
FATHERFORD's Avatar
GREAT~!!!
Just a meeting last night, got the t-shirts for the participants and trying to help everyone get organized.... The biggest problem is the lack of volunteers from parents and students.
I should be free all, ill give you a call.
Old 05-12-2011, 09:42 AM
Jetpilot2's Avatar
Well, the chirp is still there with the original alternator, but it not as bad/loud. I put the NAPA belt back on, but will getting a Green Stripe soon; off to the tuner now.
Old 05-12-2011, 10:09 AM
twinskrewd's Avatar
Who's tuning it?
Old 05-12-2011, 10:36 AM
FATHERFORD's Avatar
Originally Posted by twinskrewd
Who's tuning it?
x2
Old 05-12-2011, 11:03 AM
twinskrewd's Avatar
x2
Yep. I smell a Mustang "tooner" lmao
Old 05-12-2011, 11:32 AM
fritz4077's Avatar
i have the same problem with my accessory belt with no A/C on my lightning motor. Squeals when you first start up than once warm goes away. If i turn the fan on and leave it on for some time it will squeak once i turn off the fan the belt will stop. I will try and spin and see if its the alternator pulley. And i have a gator back belt.
Old 05-12-2011, 12:26 PM
IR0NS1N's Avatar
When you start a car and their is a squeek noise, if you spray the belt with a water bottle and the noise goes away its the belt. If its a constant noise or metalic sound its bearing. I still never would put anything on a belt. A belt thats to tight or to lose will cause a noise also.
Quick Reply: Cold Belt Noise
