running rough, but NO check engine light
Old 05-18-2011, 09:37 PM
torchred 05's Avatar
Hey, me again. Got a 98 F150 4.6 with 201,000 miles. Started running rough recently and replaced spark plugs (Motorcraft), cleaned MAF, and checked compresssion. The truck idles very rough and shudders under acceleration. Truck feels terrible and has no power. Through it all, there is no check engine light. Isn't this very unusual? I would think if the truck is misfiring, there should be a code. Any ideas? Thanks
Old 05-18-2011, 10:21 PM
Toyz's Avatar
Fuel filter been replaced recently? Recommended every 15k... people tend to let them go for too long. Would also suspect coil packs if they have miles on them or are original. You would be surprised how just one or a few misfires can make the truck fall on it's face. I had one single missfire and my truck felt like it only had half the power.
Old 05-19-2011, 10:31 AM
BLUE20004X4's Avatar
I'd replace the coil packs and wires too as mentioned above, just sounds like that is what the problem is.
Old 05-19-2011, 11:14 AM
Clogged CAT is another possibility.
Old 05-19-2011, 01:34 PM
Why do you keep starting new threads?
https://www.f150online.com/forums/v8...ing-rough.html
https://www.f150online.com/forums/v8...-injector.html
You are making it difficult to see the whole picture and you are wasting everyone's time suggesting the same things over and over again.
Old 05-19-2011, 02:00 PM
jbrew's Avatar
Great, a thread starter. Sorry, can't help....
Old 05-19-2011, 10:03 PM
SORRY FOR WASTING EVERYONE'S TIME. JUST TRYING TO FIGURE OUT MY TRUCK. I THOUGHT THE PURPOSE OF A FORUM WAS TO POST A QUESTION AND PEOPLE WHO HAVE BEEN THERE BEFORE COULD HELP ME ANSWER MY QUESTION. MULTIPLE FORUMS SO i COULD KEEP ALL MY REPAIRS CURRENT. WELL, THAT IS OK. I WILL NOT WASTE YOUR PRECIOUS TIME ANYMORE. I CAN NOT BELIEVE I AM WASTING MY TIME WRITING THIS TO THE SELECT FEW "SENSITIVE" ONES OUT THERE!!
Old 05-19-2011, 10:15 PM
jbrew's Avatar
Who r u yelling at ? Your the one trying to pull a fast one. Yea, like figuring out your crap at everyone else expense. In other words, -screw everyone else, as long as YOU figure out your problem right???
Yea, good luck with that attitude.
ByByNow
Old 05-19-2011, 11:28 PM
fritz4077's Avatar
This form needs a Like button for brews post
Old 05-20-2011, 01:47 AM
novsun88's Avatar
Not really...
Old 05-05-2013, 07:56 AM
hilltopwindow's Avatar
SO DID I find a forum that no ones on anymore? 1999 ford f150 , runs like crap and have done all the common parts change outs, maf,egr,fuel filter,plugs&coils! so anybody this is only wheels right now NEED HELP BAD! could it be ECM?
Old 05-05-2013, 10:37 AM
No codes?
Old 05-05-2013, 12:13 PM
jbrew's Avatar
Who are you referring to as no one, exactly ?
Threads: 471,039,
Members: 203,268
Yea, keep searching if that's what your after.
Old 05-05-2013, 12:20 PM
jbrew's Avatar
I want a love button.
Old 05-05-2013, 12:58 PM
jbrew's Avatar
Alright well you posted another problem, here, -
https://www.f150online.com/forums/4982573-post14.html
https://www.f150online.com/forums/4982575-post15.html
Start a new thread. Tell us what happened, then start with what you replaced first. But tell us EVERYTHING in your threads first post. Don't just spread out different problems elsewhere, - it hard to help you that way.
If you need help THAT bad, then you need to spend a little time explaining things.
You also should fill your tuck info in under "UserCP". That way we can see what you have.
I mean, is it a 4wd or 2wd ?
How many miles?
What plugs are you using EXACTLY?
What are your DTC codes?
What engine do you have?
What coils did you use and where did you get them?
Just simple stuff like that should be posted if you truly need help.
Quick Reply: running rough, but NO check engine light
