NO FPDM on my 2004 F150!!!
Old 05-24-2011, 05:57 PM
fordhound's Avatar
New to forum and a lot of great help around here from what Ive read. BUT, after having exactly same problems as others, there is absolutely NO fuel pump driver module anywhere near the spare tire crossmember, the evap stuff or the fuel rail......was there optional location Ford put the module? Thanks for any help yall can offer.
Old 05-24-2011, 10:15 PM
My 2004 had one.. Damn thing caused me to get points at for for no-show. Came out without removing bolts it was so corroded
Old 05-24-2011, 10:44 PM
2008_XL's Avatar
Do you have a 2004 Heritage (1997 - 2003) body style? If so, they do not have the FPDM. If you have a 2004 new body style, your truck has the FPDM and they're all located in the same spot which is on the drivers side right above / behind the spare on the cross member.
Old 05-24-2011, 10:55 PM
fordhound's Avatar
Thanks 2008XL - mine is the older style 2004.
Old 05-24-2011, 11:12 PM
2008_XL's Avatar
Not a problem. Try posting the issues you're having in the 1997 - 2003 section and see if anyone has any ideas. Best of luck.
Old 06-19-2014, 07:44 PM
HamRadio's Avatar
I have to agree with fordhound about his 2004 but mine is a new style. I also have a 2004 (new style) F-150 HD and it does NOT have one either. My build date is 8-1-2003. It is not shown in the Ford F-150 manual either for 2004. So I guess I don't have to worry about it rotting away.
Old 06-19-2014, 07:59 PM
Does your fuel rail have a test port and a fuel pressure regulator? If so, it does have the old return system and no FPDM.
Quick Reply: NO FPDM on my 2004 F150!!!
