Sponsored by: DashLynx
EcoBoost getting 38 more RWHP from just catback?
Old 06-02-2011, 03:36 PM
hydro1's Avatar
I've read the same quote from pick-up trucks tweet and now I'm seeing Heartthrob exhaust ads claiming 38 more Rear Wheel HP from their catback system. It seems the rumor may be true. Impressive without a tune. The best part is nothing was downloaded or touched from the ECU and you can bolt the stock exhaust right back up for warranty work .
Old 06-02-2011, 05:20 PM
Blue07STX's Avatar
I wondered how long it would be before this info was posted. I haven't seen a Dyno graph, just a claim from Heartthrob that it gained 38 rwhp. Their systems used to be similar to Flowmaster single baffle mufflers, not sure now.
Old 06-02-2011, 06:50 PM
projetmech's Avatar
yah, but what will it sound like? i had a borla on my 5.4 that i traded for the 2011 ecoboost. that last one sounded nice but this one rides so much better and has ALOT more power.
Old 06-02-2011, 07:24 PM
dejong1's Avatar
impressive if true. I want to see proof... wonder what problems it will cause
Old 06-02-2011, 08:43 PM
yellowsvt_03's Avatar
Find the ecoboost and see the dyno and sound clip
http://www.heartthrobexhaust.com/tru...inglekits.html
Old 06-02-2011, 09:00 PM
KazK's Avatar
Is that a Subaru clip?
Old 06-02-2011, 09:06 PM
Thats what I kind of thought, clip sounds like it should be on a car, not a truck. But itis what it is I guess.
Old 06-03-2011, 12:11 AM
hydro1's Avatar
Damn, you can really hear the turbo's whistle on that clip. Ford must have plugged up the exhaust real bad to muffle that. Must be the reason for such huge power gains.
It sounds just fine at WOT, the froggy unloaded neutral rev isn't all that important to me, although the turbo's sound good.
Thanks for the link yellowsvt, I couldn't find it originally
Old 06-03-2011, 07:46 AM
APT's Avatar
APT
APT is offline
I wish they would test with a Selectshift trans from way lower engine speed that can be locked in gear. I'm most interested in 1500-4000rpm than 3000-6000rpm.
Old 06-03-2011, 09:25 AM
projetmech's Avatar
i wouldnt buy it for the sound. if it comes to needing a little more horse power or it squeaks a couple mpg then it might be something to consider.
Old 06-03-2011, 11:19 AM
jpetre's Avatar
WOW, I know that the less pressure behind a turbo is better but with all the warranty talk do you think Ford will still void the warranty?
Old 06-03-2011, 11:27 AM
redtherocket's Avatar
I think these claims are bogus.
Can someone post pics up of there stock EB exhaust?
If its the same as the rest of the line up, its straight through from the factory..
The muffler changed in 2011, still straght through, but now the system has a resonator... and the muffler looks different.
You can tell the difference by sound between the 09-10's, from the 11's...
The exhausts are kinda loud on the 09-10's.
Old 06-03-2011, 11:54 AM
Jeez....the mic really picks up the turbo....
Old 06-03-2011, 12:47 PM
hydro1's Avatar
Yes, they would try, but being a cat back it's very simple to go back to stock before taking it in for warranty related to the drivetrain. A broken window switch claim wouldn't matter nor would any regular servicing.
Old 07-09-2011, 08:02 PM
truckerdude's Avatar
what are u gonna do if it breaks down on the side of the road, and you have to have it towed to the shop (and you want be able to swap back the exhaust). the dealerships sees it and if you have engine trouble they blame the exhaust and you and your warrantee are screwed.
Quick Reply: EcoBoost getting 38 more RWHP from just catback?
