5.4 Lightning torque specs
Old 06-11-2011, 06:18 PM
alerospeed2003's Avatar
I'm obviously new to this site. I am working on a 2001 lightning and I was wondering if anyone can point me towards a list of torque specs for the engine to include the s/c to intake manifold. Thanks fo the help.
Old 06-11-2011, 08:46 PM
jbrew's Avatar
Service DVD's are sold on ebay.
Old 06-11-2011, 11:46 PM
ummm.......that's it?
Old 06-11-2011, 11:50 PM
jbrew's Avatar
Yea, that's all you need. Honest.
Old 06-11-2011, 11:51 PM
jbrew's Avatar
Is it your vehicle?
Old 06-12-2011, 01:08 AM
Toyz's Avatar
That's the first thing I buy when I have a new vehicle is a manual.... can't see it any other way
Old 06-12-2011, 09:33 AM
ONELOWF's Avatar
+1
Hayne's or Chilton's are cheap enough.
Old 06-12-2011, 01:44 PM
ok......no, the vehicle is not mine, and by "that's it?" i meant i could have found a dvd or a manual for the vehicle myself, but i figured i would try one of these forums first......i can usually find one that has the specs for a vehicle i am working on. and haynes does not make a manual specifically for the lightning, just the base 5.4.....
Old 06-12-2011, 03:06 PM
jbrew's Avatar
See, that makes more sense then. The vehicle isn't yours. Since you didn't specify, figured you were to lazy to do yourself some good and get a manual. But, that's not the case, your working on another's truck. That's cool, to bad you didn't say that right off lol. Anyway, here you go -
Old 06-15-2011, 08:29 AM
next problem......
that was a start,thanx for the help. Now I need to know what the process is for taking the s/c belt pulley off of the crank. I wound up getting a haynes manual anyways, but it only covers the base 5.4, not the lightning......
Old 06-15-2011, 08:41 AM
jbrew's Avatar
Isn't that just a normal damper removal ? Off the crank should be in the book. I could look to see if it's different, off hand , I don't think so.
Old 06-15-2011, 08:56 AM
jbrew's Avatar
Yea, this is all that's on the list from service -
Old 06-15-2011, 08:58 AM
jbrew's Avatar
Crank pulley must be the same as far as removal for the base 5four.
Old 06-15-2011, 01:24 PM
I can get the balancer off, since it is the same as a normal 5.4, but the s/c belt pulley is in front of the balancer and has to come off first.........just trying to find out the exact procedure for getting that pulley off.......it looks like i would be able to use a spanner wrench and a large hex-head socket, but i am having no luck finding someone that has an adjustable spanner wrench in this hell hole........
Old 06-15-2011, 04:32 PM
jbrew's Avatar
I'll look again. Maybe I can find something on the 99's.
Alright , I have the procedure for that model year. PM your email address and I'll send it with diagrams.
Quick Reply: 5.4 Lightning torque specs
