1994-5.0 power loss
Old 06-13-2011, 06:19 PM
truckedup247's Avatar
1994-5.0 power loss
i recently purchased my first f150. its a 94 w/5.0 and 135k miles. when going up hills it is losing power. meaning i have to increase pedal to climb even a small incline. this in turn drops it into passing gear and losing gas mileage. i changed plugs, wires, rotor button and dist. cap. this didnt help. then i changed the fuel filter. this didnt help either. im about ready to look into changing out the injectors or have them cleaned out. before i do this, is there any other items i may want to check first?
there is a flashing air bag light and the fuel reset light flashes also but after reswearching i figured that was due to the faulty clock spring in the steering column.
any advice would be great. i really like the truck and i'd like it to last a long time.
BTW..it is 4wd if that matters
thanks for allowing me to join your site.
Old 06-13-2011, 09:06 PM
Matts ford's Avatar
does it lose power during normal flatland driving? or just up hills? the 5.0 stock wasnt blessed with bottom end torque, it actually served its purpose better in cars than it did in trucks because its power started to kick in in the mid rpm range. great engine dont get me wrong i really like the 5.0 but its just not meant for a truck.
now assuming it isnt normal for the truck because i'm not driving it so i dont know, does it bog down at wot? any cel? and is the tire size stock?
Old 06-14-2011, 01:41 AM
Clogged cats maybe?
Old 06-14-2011, 08:38 PM
cats were removed by previous owner. the power loss is only on hills, however when taking off from a stop it seems like it takes forever to build up speed. doesn't skip,misfire or anything like that. it feels like it is starved for gas. maybe it is just underpowered.
Old 06-14-2011, 09:19 PM
Matts ford's Avatar
well check fuel pressure, but out of curiosity what is the axle code? its on the white sheet on your door jamb
Old 06-14-2011, 10:39 PM
MTM Ford's Avatar
My 5.8, E4OD with 3:55's was the same way. You have to acquire a "feel" for the pedal to keep it from kicking down a gear and somewhat maintain speed up hills, yes even small hills. I don't think anything was wrong with my truck/is wrong with your truck, just nature of the beast.
I fixed the problem by getting an 04 with a 5.4 and 3:73's
Old 06-19-2011, 10:24 AM
the axle code is a 19. i looked it up and that means 3:55 non-limited slip. i guess i just need to get used to it being fairly weak...huh. i was really hoping to use it to maybe pull a camper or work trailer a little more. gas would kill me though. ill still give the injectors a good cleaning anyway. at least the maintenance can still be done. i like the truck a lot. always been a chevy guy, but its really growing on me
Old 06-19-2011, 11:23 AM
The 5.0 is not that great a towing engine. The 4.9 I6 has better low end torque, it just has no high end HP whatsoever.
Old 06-19-2011, 12:11 PM
jethat's Avatar
The Modular engine was such a dramatic improvement.. Especially for trucks..
Old 06-19-2011, 12:35 PM
Yep - even the 4.6 tows better than the 5.0 did.
Old 06-19-2011, 03:38 PM
jgger's Avatar
Might want to throw a compression test on it, that should tell you if it's up to snuff.
Quick Reply: 1994-5.0 power loss
