Main fuse locations..any pics ?
Old 07-25-2011, 09:08 PM
ROUSHFAN-1's Avatar
Working on my system set up...Did the "big 3" actually 4 ...but I'm trying to figure where to put the main fuse for the amp power..Using 1/0 feeders..I'm more into trying to make things look somewhat stock...It's tough fitting a large main fuse holder somewhere near the batt..Anyone have a good visible spot or hiding spot? I've done all kinds of installs and can figure something good out..Just wondering if I'm missing a good spot I'm not seeing that some one else has discovered.
Old 07-25-2011, 10:10 PM
oxfordbp's Avatar
Behind the glove box maybe?
Old 07-25-2011, 10:16 PM
ROUSHFAN-1's Avatar
too far.. you should be closer to the batt..I found a spot behind the headlight I might use..
Old 07-25-2011, 10:55 PM
oxfordbp's Avatar
It was just a thought. Glad you found a place.
Old 07-26-2011, 06:39 AM
Stormsearch's Avatar
I gave up and ended up dressing the wire and fuse holder with blue & black Techflex. I had other power wire leads also and ended up using streetwires battery clamps. I put the fuse holder on the neg battery side on the battery box.
Old 07-26-2011, 06:54 AM
Norm's Avatar
Storm, your fuse is on the positive lead though correct? You should never fuse the neg side.
Quick Reply: Main fuse locations..any pics ?
