1991 5.0 missing running rough and oil loss
Old 08-14-2011, 10:18 PM
Gemboy12's Avatar
List
I have a 1991 4x4 5.0 with an E4OD transmission 115,000 +_ miles. The truck has a miss that has gotten worse. I have changed plugs , wires rotor and cap. In addition I have replaced the vacuum reservoir that was shot, cleaned the throttle body , changed the fuel filter etc. I have had the codes pulled and I have got the following : 328,(EGR ) evap voltage, 332 EGR not opening, 542, Fuel pump ground and 634 Manual Lever Position Sensor. In addition to the missing I have found oil in the air cleaner, I replaced the PCV valve with a Motorcraft one when i discovered the oil issue. My question is this is the ERG issue causing both the missing and the oil in the air cleaner issues? or do I have more than one thing going one? I have the correct voltage ( 5.0) at the EGR sensor but I have not been able to test the sensor yet.
Any guidance would be appreciated.
Jim Barringer
Old 08-14-2011, 11:27 PM
losthillbilly73's Avatar
im not sure if the egr would cause the oil but my buddys 94 5.0 ran rough at idle and had the same codes and we put a new egr valve on and it went away. nowhis egr came off easy my 90 i broke the egr tube and had to replace the whole thing so pb blaster the hell out of it
Old 08-15-2011, 12:19 PM
Steve83's Avatar
Those definitions aren't accurate or complete; read this caption:
Don't pick the name of a part out of the definition - read & post the WHOLE thing. The EGR can't cause oil in the filter, and it can only cause a miss near idle; not at highway speed. Read these captions:
Quick Reply: 1991 5.0 missing running rough and oil loss
