1997 F-150 XLT odometer broken.
Old 08-17-2011, 04:29 PM
ole97's Avatar
Exclamation 1997 F-150 XLT odometer broken.
i have searched for a thread with this problem but none with a 97 and im not sure how much the mechanics changed throughout the generation. Not only has the odometer broken but also the trip meter isnt working. This isnt a live or die thing but i like everything to work in my truck.
Old 08-17-2011, 07:31 PM
MitchF150's Avatar
97 and 98 use a "VSS" gear located on the tail shaft of the trans (on top).
I had to change mine to a smaller gear when I got taller tires to correct the speedo/odo.
If you pull off the cover, you should be able to pull the gear out. I think there is a clip on it too, so take that off too...
Check to see if it still resembles a gear and has all it's teeth..
If the gear is okay, it could be the sender itself or even something in the gauge cluster??
I've not heard of someone with a problem like this and I've been around here since 2001..
Good luck!
Mitch
Old 08-17-2011, 08:14 PM
budmur's Avatar
Check Odometergears.com. I used their stuff to fix the odometer in my Mustang last year. This is the one you want:
http://www.odometergears.com/product...ckup+94-98/105
Old 08-17-2011, 09:21 PM
ole97's Avatar
thnks guys this problem has been puzzling me for months now.
Old 08-17-2011, 10:33 PM
Raptor05121's Avatar
Mine has been broken for some time. I swapped clusters after 20,000 miles and decided to butcher the old one. It looked like one of the gears stripped out of its holder pushing it into another gear. Just a cheap/bad design that is waiting to die. I don't understand why Ford used a digital odo in the 1995 MYs but went back to manual for 1997 and 1998
Old 08-20-2011, 08:40 AM
adrianspeeder's Avatar
Because the PSOM units in '92-'96 are starting to fail every now and then.
Adrianspeeder
Old 08-22-2011, 09:56 PM
Wraith413's Avatar
I have the same problem with my 97. Let us know what you find. I went to the dealer to price a new cluster and they wanted + $300, if they could find one. I'll definitely pull the trans gear to see if that is the problem first.
Old 08-22-2011, 10:16 PM
Tumba's Avatar
My odometer uit at 208,000, I just haven't checked it out. Looks like it's going to be a comon problem with this model.
Old 08-22-2011, 11:06 PM
paker's Avatar
Post #3 has the link for the solution. This applies to 97 and 98 only. Symptoms are odometer and trip meter not working, but speedometer is unaffected.
Old 08-23-2011, 04:46 PM
ole97's Avatar
well guys my alternator just gave out. any ideas on what thats going to cost me?
Old 08-24-2011, 02:18 AM
A lifetime warranty reman is about 150 bucks.
Old 08-28-2011, 01:09 PM
Wraith413's Avatar
Thanks, budmur! That gear you linked fixed it. I removed what was left of the original gear and it would crumble with a little bit of pressure.
Quick shipping from Odometer Gears via USPS with package tracking.
Old 10-17-2011, 02:15 PM
sweed6403's Avatar
It is most likely the worm gear on the motor that turns your odometer. I had the same problem on my 97 F-150 XLT. Its not a hard fix and you can get the gear on ebay for $24. It is inside the instrument cluster. Took maybe 2 hours only because I didn't even know what I was looking for when I started my search. I took some pictures and don't know how to up load them to this thread but if interested let me know.
Old 01-30-2012, 12:17 PM
bossgt5's Avatar
Could you please send me some photos of where you found the worm gear? I have a 97' ford xlt with a mechanical odometer and tripmeter. Neither will work. My email address is; kevinsteelwind@cablelynx.com
Thank you so much,...Mike
Old 02-05-2013, 11:18 AM
houstonmeb's Avatar
Could you please send me some photos of where you found the worm gear? I have a 97' ford xlt with a mechanical odometer and tripmeter. Neither will work. My email address is: m_baker@msn.com
Thanks,
-mike
Quick Reply: 1997 F-150 XLT odometer broken.
