2005 5.4 triton, knocking?
Old 08-18-2011, 03:09 PM
Declan's Avatar
Hello all, I have a 2005 fx4 and just recently started knocking,(always has a little) always change the oil and use motorcraft 5-20. also tried some lucas but no better. It seemed to happen after the truck sat a while(two weeks) and I started it and it seemed to be missing then that cleared up but the knocking continues. could this be oil pump? it runs fine and pressure seems good what do you guys think? and does it just need a tune up? 156,000 miles
Old 08-18-2011, 03:17 PM
Have the plugs ever been changed? Use the Advance Search and check out "cam phasers", see if this sounds like it.
Old 08-18-2011, 03:30 PM
As Bluejay pointed out>>>cam phasers
Or it could be injector related>>> https://www.f150online.com/forums/v8...ram-07m08.html
Old 08-18-2011, 04:25 PM
Declan's Avatar
I have owned it since it had approx 40,000 and no plug changes yet, what about fuel filter?
Old 08-18-2011, 04:27 PM
fuel filter should be changed about every 20,000 miles. that would not be the cause of the knocking, though. The transmission fluid and coolant need to be changed as well.
Old 08-18-2011, 04:32 PM
Declan's Avatar
ok, so the knocking is fuel related or oil?
Old 08-18-2011, 04:36 PM
Hard to say, but I bet it is mechanical. The cam phasers most likely and some go bad regardless which oil you use.
Old 08-18-2011, 04:37 PM
The plugs should have been changed at about 65,000 to 80,000 miles.
Old 08-18-2011, 04:45 PM
Declan's Avatar
I will get that done, also ballpark on those cam phasers to be fixed?
Old 08-18-2011, 04:47 PM
Declan's Avatar
also i was told a dealer has to replace the plugs, can you do that on your own or is it to rough on a weekend mechanic?
Old 08-18-2011, 04:48 PM
It may not be the cam phasers but check out this thread.
https://www.f150online.com/forums/ar...placement.html
Again, use the Search and do some reading.
Old 08-18-2011, 05:15 PM
Electron-Jack's Avatar
There are lots of things that could be wrong. With that mileage i would suspect cam phaser or vct solenoids if it only knocks at low rpm less than 1500. If it continues even as you rev the motor i would suspect a lifter or the timing chain tensioners/guides. Mine had both the lifter and timing tensioner guides shot at 172k even though the motor was clean with no sludge. If the tensioners are shot you will here a bad rattle at startup for 3-10 seconds.
Quick Reply: 2005 5.4 triton, knocking?
