Truck won't go into gear. HELP! (Video inside)
Old 08-29-2011, 08:08 PM
GA4x4Screw's Avatar
I just noticed this today after starting up my truck that the gear shifter just slides through the gears, not stopping and engaging like it should. I have a 2004 4x4 Lariat Supercrew.
Yesterday when driving I was doing 75 and moved it into 2nd gear, the rpm's immediately shot up ( I didn't notice how high) so I immediately moved it back to Drive. I drove my truck for a while after that, putting it in park, drive and reverse several times with no problems, but today it won't engage in any gear.
Heres a video. Maybe you guys know what the problem is.
http://www.youtube.com/watch?v=hUIL-O8J_VA
Old 08-29-2011, 08:20 PM
Need4racin's Avatar
crawl under and the linkage is probably disconnected where it connects to the trans.
Old 08-29-2011, 08:21 PM
johnnyvrod's Avatar
u need a sheifter actuator, its a dealer item only, cost 295 canadian i got it new on ebay for 120< take plactic try from around shifter off , and there u will see a white button u can press to disigage untill u get the part
Old 08-29-2011, 08:28 PM
supercrewzn's Avatar
Do your brake lights work? The shifter will not work if the brake lights dont.
Old 08-29-2011, 08:32 PM
GA4x4Screw's Avatar
Yes my brake lights work
Old 08-29-2011, 08:49 PM
sam1947's Avatar
My money is on the dis-connection answer from 'Need4racin'...this problem has nothing to do with the actuator or the brake lamp switch. If the linkage is not disconnected, then there is a Trans. problem.
Old 08-29-2011, 10:10 PM
GA4x4Screw's Avatar
UPDATE:
I FOUND MY PROBLEM!!!
I'm glad this didn't turn out to be more complicated and frustrating.
And you sir, are a genius. I owe you a beer.
http://www.youtube.com/watch?v=w4FeGHSV0JU
Old 08-29-2011, 11:41 PM
4 da boat's Avatar
Old 08-30-2011, 01:01 PM
nathan3306's Avatar
It's because you put the newer 4X4 stickers on her hehe... Glad you got it figured out man.
Old 08-30-2011, 05:25 PM
GA4x4Screw's Avatar
Here she is getting towed off to the dealer.
Quick Reply: Truck won't go into gear. HELP! (Video inside)
