315/70/17 on 8 inch wide wheel
Old 09-07-2011, 12:58 AM
jerrybizzle's Avatar
I should know the answer to this, but would this tire on an 8 inch wide rim be shorter than the advertised height since it was measured on a wider rim? I would assume overall diameter is smaller since the tire would have to pinch in farther with the 8 inch wide wheel. Here is advertised height and width. Cooper discover at3.
LT315/70R17 121 S D measured rim 9.5 width 12.65 height 34.35. Thanks.
Old 09-07-2011, 06:25 PM
ian51279's Avatar
The tire would actually be taller. As you pull the sidewalls in the tread of the tire "crowns".
Old 09-10-2011, 08:59 PM
I would agree that on a wider rim the tire would be a little shorter. Sidewall's would be pulled out a little more on a wider wheel. I ran 315x70x17's for year's on a 8" wheel with no problem's.
Old 09-11-2011, 01:48 PM
Did your old truck have the 3.55 or 3.73 rear end? I have 3.55 and don't know if I can justify the cost to regear as well when it comes time for new tires. I sold my travel trailer so all I tow is a 12 foot enclosed trailer. I may end up going with the 295/70/17, which I noticed u dropped to with the toyos so it won't be as hard on the transmission. I want the 315s as they are offered in a lot more tires than the 295s and would fill the wheelwells nicely. decisions, decisions.
Old 09-11-2011, 04:54 PM
My old truck had the 3.73's and were straining with the 315's. Getting an Edge programmer helped out but I found the 295x70's were a better match at 33.5 inches tall. The Toyo's were heavy at 73 lbs. ea. and netted me 1 mpg less then the 315's probably due to weight and MT tread pattern on the hwy.
Old 09-11-2011, 05:30 PM
Interesting that the smaller tire had worse mileage, but a little more understandable with it being a mt. Well thanks for the info.
Old 09-11-2011, 05:45 PM
jlyoung08's Avatar
315 70 17 on my stock wheels
Old 09-11-2011, 07:22 PM
They were smaller in diameter but heavier so I guess the stop and go driving killed the mileage a little. The best I ever got with the 315's was 18.1 on the hwy @60 mph with no AC on. This is the 315's on 17x8 wheels
Old 09-10-2017, 10:30 AM
Taylor Sterba's Avatar
Originally Posted by jlyoung08
Attachment 37479
What size lift do you have on there because I'm trying to run what you have but I don't know what lift I should get
Quick Reply: 315/70/17 on 8 inch wide wheel
