Location of radiator cap for 2000 Ford f150
Old 10-08-2011, 08:47 PM
nanaof2's Avatar
Smile Location of radiator cap for 2000 Ford f150
Can anyone tell me where I can locate the radiator cap on my 2000 Ford F150? Thank you.
Old 10-08-2011, 08:49 PM
ErikShockey's Avatar
There is no cap. I think the only cap is on the overflow reservoir.
Old 10-08-2011, 09:12 PM
snownutt's Avatar
You are correct
Old 10-08-2011, 09:32 PM
jbrew's Avatar
Called the "Degas Bottle"(cap).. Otherwise know as the "Expansion Tank"(cap).
Old 10-08-2011, 09:34 PM
jbrew's Avatar
Pic-
Old 10-09-2011, 11:53 PM
Raptor05121's Avatar
its the big round thingie
Old 09-18-2019, 02:23 AM
Steve-Stuart's Avatar
A cooling system must be under pressure so the coolant won't boil out. How can a Plastic Degas bottle handle the pressure around the cap threads to keep the system from boiling out? It needs to be a pressurized system. Please explain the theory on how it handles the pressure and doesn't boil out?
Old 09-18-2019, 05:48 AM
Fbird's Avatar
water boils at 212 degrees...(negate the coolant here....working with just water)
rough numbers best i recall .....for every 2 psi you raise the boiling point ABOUT 2 degrees BTW water boils at 212 when a SEA LEVEL.....when you are hiking in the mountains at say 4000 ft ABOVE SEA LEVEL....water boils at 206 degrees (because at that HIEGHT atmospheric pressure is NOT 14.7 psi....more like 11.5 thats why its hard to breathe.....the atmosphere is NOT pushing the "air" INTO your lungs)
https://www.engineeringtoolbox.com/b...ter-d_926.html
Sooo...if water boils at 212 @ 14.7 psi (sea level) AND we add a 16 psi cap we raise the systems pressure by 16. We get about 32 degree RISE in boiling point = 234 degree FOR JUST WATER!! now when you add in coolant (which starts at about 235) + our 32 degree rise with pressurized cap...= 267 ..ish.
Old 09-18-2019, 10:10 AM
Just because it's plastic, that doesn't mean it can't take the pressure. Many radiators now have plastic end tanks. Yeah, sounds weird to us old fogies.
Old 09-18-2019, 04:14 PM
So I live 1,500feet above sea level in the Appellation mountains and in the winter we can go down to 0F degrees so what does this all mean.
FORD Did away with the conventional radiator cap. Still, don't understand how it works.
https://www.ford-trucks.com/forums/1...iator-cap.html
Old 09-18-2019, 05:34 PM
The cap on the degas bottle is a pressure cap, that's the only cap on the system. You are making a big deal out of nothing.
Old 09-18-2019, 09:28 PM
Fbird's Avatar
it just doesn't have a "pressure release lever" like the OLD caps
Old 09-18-2019, 09:37 PM
Fbird's Avatar
means you are about 13.5 psi atmospheric pressure......so your water will boil around 210 ..so YOUR perfect 3 minute egg....will take about 3 min 15 seconds...lol....freezing point is a DIFFERENT story....almost negligible difference (we sure cant measure it close enough)
Old 09-18-2019, 11:36 PM
Freezing level is totally dependent on the strength of your antifreeze. The recommended 50/50 mix freezes at -34F. Your boiling point with 50/50 and 16 psi is around 265F.
Old 09-19-2019, 09:07 PM
Bluegrass's Avatar
Any anti freeze material mixes with the water and gets between the water molecules so they can't stick together.
Pressure is a separate function.
Both are present in the same system at the same time.
The bottle cap is a pressure cap both ways same as any other cap.
The total system design is dependent on how much heat has to be passed to air through the core.
This depends on the amount of heat the engine generates under max load, road speed, system pressure, worst case ambient temps and at what engine temperature range the engine is designed for, fan CFM, clutch cut in and out etc.
Then add to all this the automatic transmission heat that is sent through a separate coil on the driver side of the core.
All the trucks are built with the same systems for the last 25 plus years.
Unless you can accept factory engineering, don't worry about it.
If there is an issue, it will let you know.
Good luck.
Quick Reply: Location of radiator cap for 2000 Ford f150
