05 f150 supercrew 5.4 spark plugs
Old 12-10-2011, 05:13 PM
rman550's Avatar
Bought truck used with 136k on it to replace my 03 supercrew 4.6 that was totaled in a accident on nov 17 [t-boned on drivers side]. Getting code P0420, Catalyst system efficiency below threshold [bank1]. Was told #2 has misfire. Was advised to replace spark plugs. Been reading all the horror stories about these plugs breaking upon removal. Couple Questions, I am in Virginia Beach, Va and was wondering if anyone on here is near my area, that might be able to help me with this because I am busted up a bit from the accident? Also, what are the best reliable replacment plugs for this engine? Read pro's and con's about the Champion #7989, and the Motorcraft SP-515 Thanks in advance for any help with this.
Richard
Old 12-10-2011, 07:36 PM
BlackOut07's Avatar
Changing the plugs is pretty easy even if they break, that is as long as you have the extractor tool. I think the stories make the plug change sound worse than it really is.
I mean if it breaks you just use the porcelain pusher tool, takes maybe a minute or so depending on how efficiently you work. Thread the tap rod into the plug, takes another minute or so. Pull it out, bam done, onto the next one! lol
Old 12-11-2011, 01:39 AM
marklt6002's Avatar
x2,thats right if you have the lisle tool you wont even care if you break plugs left and right,just follow the instructions.(dont get into it with out an extraction tool) I would go with the motorcraft,the champion 7989 is around 20 dlls. Good luck
Old 12-11-2011, 10:22 AM
People have been having mixed luck with the Champions. I'd use SP-515's.
Old 12-11-2011, 10:31 AM
westtnfx4's Avatar
I run a bottle of sea foam threw the truck to remove any carbon buildup around the base of the plug (inside the head on the shaft) that makes the breaking less likely. I have not had any to break so far and I've never used any thing but a socket and extension. If you are banged up from the wreck you will prolly not want to try this because it takes some maneuvering around the engine compartment. If I were close I'd help you. But if you can't find anyone you may want to take it to a shop and have them do it.
Quick Reply: 05 f150 supercrew 5.4 spark plugs
