Idle position sensor
Old 12-12-2011, 08:53 AM
hopperwagonbob's Avatar
Anyone know where it's located on a 2001 5.4? Truck won't idle now that it's cold until it warms up. Thanks
Old 12-12-2011, 02:33 PM
It's not a sensor, it's an IAC (idle air control) valve and it's attached to the throttle body.
Old 12-12-2011, 03:46 PM
Great I found it back by the firewall. Don't know if it's my problem or not. Thanks
Old 12-13-2011, 03:12 AM
Pull it and clean it. Spray some WD-40 into it and work the plunger with a screwdriver till it moves freely. See if that helps.
Old 12-13-2011, 06:03 AM
Yea that's what I did it was dirty. Ford wanted 121.00 for a new one. I'll try it this morning after it cools down over nite. Thanks
Old 12-13-2011, 01:55 PM
Motorcraft IAC is $65.79 at rockauto.com, and a gasket is $1.11.
Old 12-14-2011, 09:23 PM
robert york's Avatar
i have a 97 f150 4.9 liter doing the same thing,could that be my problem too?
Old 12-16-2011, 09:36 PM
Well it fixed mine.
Old 12-16-2011, 11:06 PM
jethat's Avatar
I've used the autozone IAC for a few years now with no issues. seems like it was 39.95 or so..
Old 12-16-2011, 11:08 PM
efuehrin's Avatar
it could be the throttle position sensor also.
Mine went out and it wouldn't idle well plus the jacked the transmission all up.
It's on the throttle body. Easy fix.
Old 12-17-2011, 10:37 AM
ONELOWF's Avatar
^^^^ Right. Voltage check instructions here: https://www.f150online.com/forums/li...ttle-body.html
Old 12-21-2011, 10:21 PM
I've never seen a 1997 with a 4.9.
Old 12-27-2011, 08:48 PM
well i guess i have the only one with a 4.9 liter in it.
Old 12-27-2011, 09:19 PM
Toyz's Avatar
Is that a 4.6L bored over .20? J/K
You have a 4.6L if you have a 97 bud
Old 12-27-2011, 09:37 PM
A 4.9 is an inline 6.
Quick Reply: Idle position sensor
