04 f150 starting problem HELP!!!!
Old 12-15-2011, 02:48 PM
mbhaddock's Avatar
i have a 04 F150 FX4 5.4 it will turn over but not start. i have replaced the fuel pump, fuel pump driver module and filter. it will start with a little starting fulid but only run for bout 4 seconds. i also checked the inertia switch. i just dont know what else to check. Thanks
Old 12-15-2011, 02:52 PM
kevhead75's Avatar
Any Codes? Checked your fuses yet?
Old 12-15-2011, 02:55 PM
mbhaddock's Avatar
yea i checked all my fuses. and it gives me a code P01233 saying the fuel pump driver module offline
Old 12-15-2011, 02:59 PM
kevhead75's Avatar
Check the FPDM again. Make sure the plug is seated correctly. Also I believe the unit needs to be grounded so clean any corrosion around the bolts.Check the inertia switch again, make sure it is reset.
Old 12-15-2011, 03:11 PM
kevhead75's Avatar
I stand corrected, it grounds thru the harness.
Old 12-15-2011, 03:26 PM
mbhaddock's Avatar
i just checked it again and everything is good. i disconnected fuel line before the filter and turned the key and there is no fuel flow
Old 12-15-2011, 04:21 PM
kevhead75's Avatar
That just confirms that the FPDM is not working as does the P1233 code. You may need to locate a wiring diagram and see if there is power or an open ground in the wiring. Don't forget the inertia switch is part of the circuit.
Old 12-15-2011, 06:24 PM
mbhaddock's Avatar
thank you for your help it ended up being the grounding wire that grounds the cab to the frame the bolt was loose
Old 12-16-2011, 10:09 AM
kevhead75's Avatar
Glad you got it figured out. Always nice when people actually post the result of what fixed the issue.
Cheers
Old 12-29-2011, 01:55 PM
Shaunk23's Avatar
Assuming that you attempted to jump your truck, did it start then at all? I woke up this morning and my truck turned over once and then the starter just started clicking. When i jumped it, it fired up right away and i ran it for 30 minutes and after in hour it was dead again. I cleaned the terminal posts but haven't had a chance to jump it again. If that doesn't fix it i believe it could be my alternator. But is it possible that a bad ground could be the cause as well? I want to think no since it fired up with a jump. Any help would be greatly appreciated!
Old 12-29-2011, 02:20 PM
kevhead75's Avatar
Usually better to start your own thread pertaining to your own problem. You will usually get better answers that way.
Sounds like a bad battery or alternator. Many of the chain auto parts stores will check your charging system and battery for free. Advanced auto, O reillys or autozone will do it for free. No need to remove anything, just go to the store and they will check it out.
Kev
Quick Reply: 04 f150 starting problem HELP!!!!
