Oil filter change 2003 F150 5.4 V8
Old 01-31-2012, 05:45 PM
wolfdidditz's Avatar
I feel kind of like a dumb a**. I have bought 2 different oil filter wrenches and still can't get the oil filter off my 03 F150. It's a tight fit and I'm getting frustrated with it.
Old 01-31-2012, 05:54 PM
steven'sf1504x4's Avatar
it can be a pain have u tried the screw driver trick?? Take a hammer and long screw driver and put the screw driver threw the filter. Its a tight fit but id try it. I've never been able to get my filter off by hand. And usually I can on all my familes cars I tightne them all the same hmmm weird. Oh well
Old 01-31-2012, 06:13 PM
CManHugh's Avatar
Wolfdidditz, have you seen the one that you use a socket wrench with?? I don't suggest using a hammer and screw driver, sometimes paietience is required, just like the other day my fuel filter wouldn't come off and I was really thinking about cutting it off... Link below for the tool...
http://shop.advanceautoparts.com/web...T|GRP2082_____
Old 01-31-2012, 06:21 PM
Thumbs up
I'm going to order the socket one. Bought my first 2 wrenches from Walmart. I will do the screwdriver hammer trick for now. thanks for the info
Old 01-31-2012, 06:34 PM
sam1947's Avatar
"Google" for ' KD' Tools for # 2029 Filter Wrench...works great !!
Old 01-31-2012, 07:11 PM
And a friendly bit of advice if you are new to Ford trucks - use Motorcraft 5W-20 semi-synthetic oil and a Motorcraft FL-820S filter. Both are available at Walmart. Whatever you do, do *NOT* put a Fram "orange can of death" on it.
Old 01-31-2012, 07:12 PM
jspansel's Avatar
Where is the filter on the 03?
I have a 99 5.4 4x4 and it is right up in the fender well on the drivers side. Very easy and accessible. I have read something about a relocation kit? Is my location not stock? I think my manual even said it was up above the T-Case or something. Sure glad it wasnt.
Old 01-31-2012, 07:48 PM
enriched's Avatar
I got one like this http://www.amazon.com/Tools-3288-Uni...sim_sbs_auto_6
...but wish the fingers were deeper, to get a better /deeper grip on the filter. I'm sure there are some out there that are deeper.
for the most part it works well, I usually put extensions on & give a couple of smakes to collapses the dome of the filter, then it bites better.
I agree it is a booger to get to.
Old 01-31-2012, 08:56 PM
jethat's Avatar
I wouldnt use the screw driver deal you could rip the filter in half and end up having to call a wrecker because you cant get it off. If there stuck like that take it in and have it done..
Old 01-31-2012, 11:25 PM
Toyz's Avatar
The filter on my Audi 2.7T is always stuck on from heat. I have broken numerous wrenches and had to buy a heavy duty wrench that I could use a cheater bar on... imagine that yea. But, good news is, someone told me try to slip a piece of sand paper between the filter wrench and filter and try it that way... First time I tried it, with no cheater bar, came right off. I faced the grit toward the filter. Cut a strip about 1" wide and 6 or so inches long and put it between the wrench once I had it over the filter. Turned it tight and gave it a quick tug, came off. You should try that.
X2
Did that once a while back on my ranger.. outcome was not good.
Old 01-31-2012, 11:30 PM
Toyz's Avatar
Some models came with the relocation kit, behind the front bumpers. Others were just mounted to the block above the transfer case... like mine.
Old 01-31-2012, 11:39 PM
jspansel's Avatar
Thanks. Was not sure why it was not where it was supposed to be.
Old 02-01-2012, 06:57 AM
enriched's Avatar
I had to use the sand paper deal in the past too...it does work...just a bit tricky to get everything in there to stay well enough to put into action...but that was on a vertical mount filter.
The screwdriver situation can turn ugly fast...worked better back in a day when material on the outer casing was a bit heavier/thicker and you had bit more room.
that is what is appealing with the K&N filters, they have a nut on the end of the filter....not sure how they rate for filtration though
Old 02-01-2012, 02:12 PM
A K&N OIL filter is a very high quality filter - it's the same internals as a Mobil 1 filter. It's designed for extended drain interval synthetic oil.
Old 02-02-2012, 01:32 AM
AndersonS's Avatar
Whatever method you choose, do yourself a favor and don't overtighten the new filter. Tighten until gasket contact and then maybe a half turn more.
Quick Reply: Oil filter change 2003 F150 5.4 V8
