trailer connection is dead help please
Old 02-05-2012, 06:07 PM
mattman89's Avatar
so my trailer connector is dead from my truck to the trailer, no lights on the trailer.......idk where to look for the fuse(which fuse) or the relay. im goin nuts over this. its an 07 f150 4x4 5.4 super cab.
Old 02-05-2012, 09:17 PM
kc0stp's Avatar
First off check your owners manual for a fuse diagram so you know which fuse to look for, not sure on the 07 but on my '10 theres a fuse box right behind the radiator that contains all the trailer fuses and relays. Figuring those check out start at the connector and work your way forward looking for broken wires (small animals chewing them or corrosion)
*edit* heres the info on the fuse box for your truck https://www.f150online.com/forums/2016049-post20.html
Old 02-06-2012, 12:28 AM
mattman89's Avatar
thanks ive figured out that i have some power back there , the turn signals,and brake light. when i hook up the test light for the running lights, the test light is very dim.?????????????????????
Old 02-06-2012, 12:30 AM
mattman89's Avatar
and i didnt find a fuse box under the hood. and all the fuses and relays are ok.
Old 02-06-2012, 11:58 AM
glc is online now
Have you looked in your owners manual yet?
Old 03-11-2012, 10:58 AM
Jolly_Green_Giant's Avatar
Are you sure all of the fuses are good? I've had this happen a few times before.
This will sound wierd but is there power to the cigarette lighter below the radio?
For some reason, they are on the same fuse. I don't remember exactly which fuse it is. But it's in the fuse panel located behind the pasenger kick panel. On the row of fuses closest to the firewall. It's pretty hard to see without being on your head in the floorboard. I'd check this location very carefuly
Somewhere between F06 and F10
Old 03-12-2012, 09:23 AM
SETCHAN's Avatar
Build Tracking Moderator
Check the Ground wire for good contact ?
Old 03-19-2012, 09:39 AM
mattman89's Avatar
thanks all. i gave up and took it in, somehow i missed a fuse and i had a bad relay which i didnt understand cause i moved them all around.
Quick Reply: trailer connection is dead help please
