Caliper bolt torqure specs
Old 02-15-2012, 01:43 AM
wyattboche's Avatar
I need the caliper torque numbers for a 2005 f150 6 lug. I'm replacing my brakes(rotors and pads) this weekend, is there anything I need to know?
Old 02-15-2012, 05:10 AM
04fxdwgi's Avatar
According to my manual.......
If you are talking about bolts that hold front caliper mount bracket to knuckle.. pre-2009 are 148 lbft.
If you are talking about the caliper mounting pins, then... Pre-2007 are 47 lbft
The rear pins are... 22 lbft for all years
1. Make sure all mating surfaces are cleaned w/ light grease film (I use NeverSieze) on them.
2. Make sure the fulcrum actuator for the rear e-brake is clean, moves free and is lubricated.
3. Be sure e-brake is adjusted correctly to prevent dragging.
Other than item #2 and 3, just a std disc brake job, like every other vehicle.
Did mine a couple of weeks ago and like night and day. E-brake even works now....
Old 02-15-2012, 01:33 PM
wyattboche's Avatar
Thanks.
Old 12-07-2012, 08:23 PM
junior's Avatar
Same question...but for 2009-2011? Are they still 13mm and 18mm bolts? The torques for the bolts involved in a rotor pad swap would be greatly appreciated.
Quick Reply: Caliper bolt torqure specs
