98 F150 Electronic 4wd not working
Old 03-13-2012, 08:34 PM
JJ88's Avatar
I have a 98 F150 5.4l with electronic 4wd but when I go to turn it on the light doesnt come on and it doesnt engage.
Old 03-13-2012, 08:46 PM
znb1988's Avatar
Had same problem with mine nothing would happen. Turned out to be a bad transfer case shift motor. Changed it out and works fine now.
Old 03-14-2012, 09:58 AM
JJ88's Avatar
Is that costly?
Old 03-14-2012, 10:17 AM
1997 lariat 4.6's Avatar
there are also resistors in the dash that go out. knock on wood i haven't had to deal with this yet..
Old 03-14-2012, 01:46 PM
chub's Avatar
Try rapping the motor with a small hammer they do stick . Worked on mine
Old 03-14-2012, 02:01 PM
do you hear the dash clicking? if not resistors, or switch. If it does click its your t-case motor. If his dash light isn't coming on it has to be an electrical issue, not mechanical.
Old 03-14-2012, 04:06 PM
JJ88's Avatar
Yeah it clicks but not everytime
Old 03-14-2012, 11:11 PM
try swapping your switch first if it doesn't always click.
Old 03-17-2012, 07:11 PM
JJ88's Avatar
what is that switch called?
Old 03-17-2012, 09:43 PM
the 4x4 selector switch. its electronic right?
Old 03-18-2012, 05:44 PM
JJ88's Avatar
yes
Old 03-19-2012, 08:13 PM
znb1988's Avatar
Mine was doing same as yours is doing. It is not clicking in the dash because it is not completing the circuit between switch and motor. Mind would work for a minute then kick out of 4wd. Then it finally just stuck in 4wd. Troubleshoot it and mine turned out to be t-case shift motor.
Quick Reply: 98 F150 Electronic 4wd not working
