Axle Weights??
Old 03-25-2012, 04:22 PM
Galaxy's Avatar
Axle Weights??
Anyone weighed their truck (4WD supercrew preferably) lately on the scales and gotten individual front & rear axle weights??? Just curious.
No...I'm not looking for a total weight of the truck; got that.
Old 04-18-2012, 09:41 PM
Galaxy's Avatar
Bueler…Bueler...
Old 04-20-2012, 12:50 AM
jbrew's Avatar
Doesn't it say that inside the door ? Front 3600/Rear 3200 or something like that ?
Old 04-20-2012, 09:22 AM
Galaxy's Avatar
If it does (and I believe your absolutely right), then that's max allowable axle weight, not current sitting in the parking lot weight...I know my truck does't weigh 6,800 lbs.
Old 04-20-2012, 09:58 AM
jbrew's Avatar
Ahhh, - your right, they are lighter than that on the scales. I recall shipping weight of my truck was something like 4800 lbs when I ordered it. I didn't believe it was that light at the time.
Old 04-20-2012, 12:13 PM
Galaxy's Avatar
I've my truck weighed on two different scales over the years and both times it was 5,300-5,500 lbs; that's normal, full tank of gas, completely unloaded, ready to drive. AND, that 5,500 is with my lift, wheel/tires, etc. I was just curious about the split (for no particular reason) without going back to the scales, cause it's most certainly not 50/50.
Old 04-20-2012, 01:10 PM
jbrew's Avatar
Yea, front end is allot heavier. I have my truck roller dollies right now so I slide it sideways in the garage if I need to easily. That was the plan anyway. The dollies are rated to 1500 lbs apiece, -1 per wheel.
Dollies are 1/4" steel w/3" castors. Dollies in front are sweating it lol. They haven't bent yet and it does work. It's a PITA to swing the front, I have to grunt a little, but I can do it. Well, until I hit the expansion joint in the concrete floor. I have get a little momentum going first and hope it's enough or I end up face planting into the fender.
So it's heavier up there, definitely.
Old 04-20-2012, 04:31 PM
MitchF150's Avatar
I have them, but it's when I had my TT hitched up... Not sure if that's gonna help you, but it did tell me that I'm over weight on my truck!
When I rolled over the scales my axles weighed as follows;
trailer axles: #4540
truck Rear axle: #3400
truck Frt axle: #3080
This was done with me NOT in the truck (I had to read the scale weight at the closed truck weigh station from outside the booth!)
So, I'm another #230 of weight to the truck...
Trailer works out to have ~ #700 tongue weight. I was #460 over the trucks GVWR and #200 over the rear GAWR...
Oh well... What can I say?? I've towed this combo for over 9 years and going to do it again this year!
Mitch
Old 04-20-2012, 10:23 PM
jbrew's Avatar
So if the tongue weight is at 700 lbs. I wonder how much that would take off the front axle ? A couple hundred, - if that, - probably not even.
Old 04-21-2012, 12:09 AM
MitchF150's Avatar
I should also mention that I had the weight distribution hitch set too, so some of that was transferred to the front by it.
Mitch
Old 04-21-2012, 01:40 AM
Galaxy's Avatar
Yea, but I can tell be ride height alone with my WD hitch and air bags, quite a bit of weight is taken off the front.
Old 04-21-2012, 02:29 AM
jbrew's Avatar
Yea, I'm not sure how you could add weight to the front without a fifth wheel hitch/slider set up or a goose neck perhaps. My front end came up as well.
Old 04-22-2012, 11:16 PM
FordsRock98's Avatar
Was on the scales Tuesday my truck weighs 5420lb like it sits, add the 1600lb trailer and I'm 7020lbs. I towed in at 7620lbs at the dump had to get a new weight card because I added my ladder rack back on. I hate pulling more than I have to esp with my personal truck.
Sucks bad too, maybe I should remove my nerf bars and the heavy tools, need to lighten 600lbs or more off that trailer too. I put air bags on the rear so my front doesn't raise and the rear doesnt sag. Wish I had the 7700 series now, just cause I has a 9.75" rear doesn't make me feel any better. I have the E4OD for the F250 in my family room getting rebuilt.
Old 04-26-2012, 01:24 PM
Spend the 10 bucks and go run it over a CAT scale to get individual axle weights. The Pilots and Flying J's have them in your area.
Old 04-27-2012, 12:28 AM
jbrew's Avatar
Cool, you must have the wife helpin yuh ? It's great when they understand and offer use of the facilities. Like the kitchen table and counter tops.
Right, what am I saying, or - dreaming rather...Like that ever happens.
Quick Reply: Axle Weights??
