Spark plug replacement 4.6 engine
Old 03-26-2012, 05:01 PM
kpg7121's Avatar
Truck is an '07 with 80,000 miles & with the 4.6 engine. I've owned the truck for a year & want to replace the plugs. Dealer wants $300 bucks to do it, plus tax. Does this engine have the issue with the plugs breaking off? I'm fairly good with a wrench, but should I just let the pros do it & couph up the $300? Any special tips, tricks to accomplish this without any major headaches? Thanx a bunch!
Old 03-26-2012, 05:22 PM
No, the 4.6 does not have the problem. Just be careful working with the alum heads and use Motorcraft plugs.
Old 03-26-2012, 05:24 PM
This is in the Articles and How To, older engine, but not much was changed.
https://www.f150online.com/forums/ar...ange-pics.html
Old 03-26-2012, 06:53 PM
monoxide's Avatar
the 4.6 is easy its a little tougher if your a big guy like me tho.
Old 03-26-2012, 07:44 PM
$300 is excessive, your dealer is trying to take you to the cleaners. Use Motorcraft plugs, do not use antiseize, and torque them to 28 ft/lb. Use dielectric grease in the COP boots when reinstalling.
Old 03-27-2012, 05:06 AM
kpg7121's Avatar
Thanx for the replies & the link to the write up. I see that the OEM plugs are like $.3.50 at Advance Auto. The quote from the dealer included replacing the boots which are like $6 bucks a piece. So he wants about $240 for labor. Nah, I'll do it myself. Should I soak the plugs in PB before I pull them & does it matter if the engine is cold or warm? Just want to avoid any headaces.
Old 03-27-2012, 07:19 AM
DSGSTX81's Avatar
My dealership just quoted me $469 to do it on the 2v 4.6
I almost s*** a chicken on the spot....
Old 03-27-2012, 07:32 AM
MGDfan's Avatar
Mornin'!
Room temperature, no PB blaster required.
Just ensure you blow out the plug wells with air to eject all the spooge
Good luck!
MGD
Old 03-27-2012, 12:07 PM
Make sure the plugs are genuine Motorcraft, not OEM "replacement" Autolites.......
Motorcraft SP493's are $2.49 each at rockauto.com, and Motorcraft WR6128 COP boots are $5.79.
The dealer is charging you full retail for the plugs and boots, which probably puts the parts bill up around the $150 range. With that, $300 isn't that bad.
Old 03-27-2012, 12:16 PM
GTNOS's Avatar
nevermind
Old 03-27-2012, 02:52 PM
dixie_boysles's Avatar
If you go to advance Auto online, put in the code VISA, or P20 and you will get a nice discount!
Old 03-27-2012, 10:23 PM
monoxide's Avatar
i need to do my plugs again. i had a misfire so i just threw some autolites in and would much rather have motorcraft but i was broke at the time. so next oil change they will get changed prolly
Quick Reply: Spark plug replacement 4.6 engine
