Fuel Gauge not working
Old 04-04-2012, 09:10 PM
nameiscensored's Avatar
My Fuel gauge hasnt been working properly for about 2 months now. 2005 F150 5.4L fx4. It randomly goes from past full to empty and every where in between stays at one spot for a couple days then randomly switches. The mechanics said they checke my fuel gauge seems to be working and replaced the fuel sending unit. Any ideas on this issue?
Old 04-05-2012, 12:15 PM
mkosu04's Avatar
mine does the same thing! It goes from full to empty. It will stay at one spot for awhile (usually when I don't drive around) but then it seems to drop faster when I drive more. I don't understand it!
Old 04-06-2012, 09:26 PM
ok just found out what is wrong I will write down the information from on the paperwork tomorrow. What has happened basically though is there is sulfur build up in the tank for mine at least which causes the fuel sending unit to go bad and also a sensor to go bad and you have to have them both replaced. Like I said I will have the information to ya tomorrow. I spent a ridiculous $630 getting the pump replaced now I have to get the sensor replaced which is about $250
Old 04-06-2012, 09:29 PM
Nevermind found it online.
There is a TSB on high sulfur fuel usage, and how it impacts the fuel level resistance.
If you change fuel, it might start working again. The TSB is : ERRATIC FUEL GAUGE OPERATION TSB 08-2-9
Publication Date: January 22, 2008
FORD: 2004-2008 F-150
LINCOLN: 2006-2008 Mark LT
ISSUE:
Some 2004-2008 F-150 and 2006-2008 Mark LT vehicles, built before 12/3/2007, may exhibit erratic fuel gauge operation or illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0460 or P0463, and/or Instrument Cluster Module DTC B1201. This may be caused by sulfur contamination in the fuel causing an open or high resistance in the fuel level sender.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Install a new fuel level sender following the service procedure instruction sheet provided in the fuel sender kit.
PART NUMBER PART NAME
8L3Z-9A213-E Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-26 Gal Tank - 126/132" WB )
8L3Z-9A213-F Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-30 Gal Tank - 139" WB)
8L3Z-9A213-G Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-27 Gal Tank - 145/151/163" WB
8L3Z-9A213-H Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-36 Gal Tank - 145/151/163" WB
8L3Z-9A213-A Kit - Fuel Sender (2004 through 2008 - Gas-26 Gal Tank - 126/132" WB
8L3Z-9A213-B Kit - Fuel Sender (2004 through 2008 - Gas-30 Gal Tank - 139" WB
8L3Z-9A213-C Kit - Fuel Sender (2004 through 2008 - Gas-27 Gal Tank - 145/151/163" WB
8L3Z-9A213-D Kit - Fuel Sender (2004 through 2008 - Gas-36 Gal Tank - 145/151/163"WB
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
080209A 2004-2008 F-150, 2006-2008 Mark LT: Install New Fuel Level Sender, Includes Time To Remove And Install Fuel Tank (Do Not Use With 9002A, 9002A4, 9002A6) 1.9 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
9A299 42
Old 04-07-2012, 02:39 PM
glc is online now
If I were you, I'd change gas brands.
Old 04-09-2012, 06:41 PM
yep going to see if that helps.
Old 08-02-2013, 03:51 PM
Gmar88's Avatar
Well all sudden my 2011 ford f-150 went to empty on the fuel gauge and hasnt been working since this happend couple days ago, might this be same problem?
Old 08-02-2013, 05:24 PM
Piossibly. When my truck did this, it was a bad Fuel Sending Unit. After that $380 repair, I stopped getting gasoline from Sheetz and started paying for the pricier fuel. Been good ever since.
Quick Reply: Fuel Gauge not working
