Need help removing Fan Clutch
Old 05-01-2012, 10:15 PM
chuck gibson's Avatar
Hey Folks,
I have a 2000 4.6 F150 that has a couple of burned valves and I am in the process of removing the heads. I have hit a stump... The fan clutch is attached to the water pump pulley with one large nut. When I turn the nut the pulley just spins. How can I hold this pulley to remove the clutch? Also, I have read in one book that this clutch has left handed threads and I have read in another book that it has right handed threads. Which is correct?
Thank you much!
Chuck
Old 05-01-2012, 10:21 PM
Gotts2BMe's Avatar
regular lefty loosy, righty tighty. Get yourself a baar or a big screwdriver and put it between the water pump pulley bolts and clutch fan and spin it off with a big crescent wrench
Old 05-01-2012, 11:22 PM
str8t six's Avatar
Rent the tool from a auto parts store. Works like a charm!!
And yes it's left to loosen it.
Old 05-02-2012, 08:08 AM
fairlaner's Avatar
This is how I do it ... saves me a trip to town
Pic from my 4.2 timing cover gasket replacement how-to ...
Old 05-02-2012, 05:05 PM
grizzstang's Avatar
I used a locking chain wrench wrapped around the pulley.
Old 05-02-2012, 05:16 PM
jethat's Avatar
I've done it with a chisel. Smack the bolt on the counterclock wise side to break it loose.
Old 07-23-2012, 02:35 PM
D Ryan's Avatar
I have to ask!
This looks like a strap wrench on the pulley! And you wedged a long screwdriver between 2 water pump bolt diagnally for a backstop! Then smacked the cresent with a Hammer!
Is that what you did?
Old 07-23-2012, 03:30 PM
Ross-FX4's Avatar
Whooooops. Double post.
Ross-FX4's Avatar
An Air Hammer / Chipper if you have the capability.
3-5 second wack and she will turn.
Old 07-23-2012, 06:01 PM
Red02FX4's Avatar
Originally Posted by D Ryan
I have to ask!
Only look at the screwdriver and crescent wrench.... and then.... yes, hold the screwdriver diagonal between to pulley bolts then push down on the crescent.
Old 07-23-2012, 07:19 PM
czar1998's Avatar
I rented the tool from O'Reilly's. Mine loosened in the normal (lefty) direction but you are right, both threads are out there. If you have a backwards threaded fan clutch it will say on the label on the fan shroud. If it doesn't say, it is normal direction.
CZ
Old 07-24-2012, 04:30 AM
fairlaner's Avatar
I have to ask!
You busted me
The strap wrench was a weak attempt to hold the pulley before I said screw it and jammed a screwdriver between the pulley bolts. No hammer was required.
Quick Reply: Need help removing Fan Clutch
