Spare Tire Crank Tool
Old 06-15-2012, 12:18 AM
Mike A.'s Avatar
My truck came (used) without the crank for the spare as many seem to. Looked forever for a replacement but wasn't going to pay $50 - $80 for one on ebay especially when I already had a jack and lug wrench. Junkyards around here never have any. Found some threads where people had bought bar stock or ground down 1/2" socket extensions to fit, but figured there must be something out there.
Finally found a decent replacement:
CTA Tools 4359 Spare Tire Tool-White
It's the white-coded tool in this set.
It's just a long steel rod with a 7/16ths square drive on one end to fit the socket that turns the crank for the spare and a 3/8" socket on the other end. Says "07 and up" but fits 2004 - 2008. Looks to be a well-made tool. I could easily turn mine by hand so didn't even need to break out a ratchet.
About $13 + shipping = ~$23 to me from here:
http://paceperformance.com/i-5926904...-e-series.html
Or here might be less with shipping depending on where you are:
http://www.jbtoolsales.com/CTA-Tools...ire-Tool-White
Both drop-ship from the manufacturer so it takes a week or more to get it in.
Yeah! No more tire in my bed! lol Anyway, thought this might be helpful to somebody out there who's also looking.
Old 06-15-2012, 09:10 AM
SoonerTruck's Avatar
Does it break down into a smaller piece than that? It's just a little long to be carrying in the cab, as well as whatever you need to turn the thing.
Old 06-15-2012, 02:40 PM
Mike A.'s Avatar
Naaa... Doesn't break down. I just tossed it in my truck box so no big deal in my case. The kit's really made for guys doing road/tire service versus owners. Given a choice I'd probably prefer one that did but for whatever reason the things seem to be like hen's teeth to find.
Old 10-13-2013, 10:41 PM
Rambo's Avatar
I lost my original spare tire tool kit and just ordered one of these.
Is this the only tool needed to raise and lower the spare tire?
Old 10-14-2013, 07:21 AM
60DRB's Avatar
...plus a 3/8" ratchet/breaker bar to turn it. Looks like a good replacement option. I actually like the idea of a one piece rod instead of the individual pieces.
Now, what about turning the jack? One of the OEM rod segments has a hook that goes into the hole on the jack screw end.
Old 10-16-2013, 07:30 PM
wilburzz's Avatar
saw this on my local craigs list. says he will ship.
http://miami.craigslist.org/pbc/pts/4109174788.html
Old 10-17-2013, 03:38 PM
60DRB's Avatar
...same as my older '92 F-150 jack. Will work fine.
Old 03-22-2014, 01:55 PM
tsevrens's Avatar
When I bought my '04 F150 it didn't come with the crank tool either. I tried to use one from my brothers '96 F150 but it didn't want to fit properly.
Anyone know the correct size I'd need to order for this? I like the idea of having just one long tool to get the job done.
Old 03-23-2014, 07:56 AM
60DRB's Avatar
It would seem that about half of the auto owners in the USA keep the tire changing tools when they sell their vehicle. How weird is that?
Old 03-23-2014, 02:02 PM
I would never use the scissor lift that came with the truck... just don't trust it.
I've got 2 10 ton bottle jacks and a 2 1/2 ton low pro cheap HF floor jack along with about 1/2 of a shop in the back of my truck. I could change out practically anything on the side of the road.
Old 03-24-2014, 09:52 AM
Don't trust what about it? Obviously it's not ideal for everyday use, but it's fine for a roadside emergency. It's no less stable than a comparable footprint bottle jack.
Old 03-24-2014, 09:28 PM
It's the fact that I've had one fail on me before. The thing collapsed on me. Luckily I didn't lose any fingers or my hand, because I know better.
A 10 ton bottle jack is not going to break lifting a corner of a 1/2 ton pickup. At least I haven't had one that is maintained fail on me. I've had ones that had never been properly maintained fail on me.
I wouldn't even think of using my bottle jack on my truck only because I have my floor jack. If my floor jack died, then I'd use the bottle jack.
Personally, I like using floor jacks, because I can stay far away if something decided to let loose, including the jack itself.
But in either case, I have 2 10 ton rated safety stands that I put under and slowly raise them as I raise the chassis with the jack. This way if it falls, it ain't falling far.
Old 03-25-2014, 10:36 AM
Again, the jack is fine for an emergency, not for common maintenance. A floor jack is the only jack I'd use for normal maintenance (tire rotations, repairs, etc) combined with jack stands. The factory scissor jack is good enough for a quick tire change on the side of the road, instead of dragging around a 40lbs floor jack in the bed all of the time. The bottle jack is another compact substitute, but I don't really value one much over the other, either can fail. I can't imagine that Ford (or any car company) would provide a jack that wasn't rated to lift the heaviest corner of a factory truck, with plenty of margin to spare.
Old 04-26-2014, 04:12 PM
tystark's Avatar
Spare Tire Winch Tool
Thank-you for the information. The thread took the mystery out of the tool. I bought my truck used and it did not come with the tool. I believe that they must be in same place as single socks. lol Once I discovered that the tool is simply a very long 1/2" ratchet drive extension, I bought two 10" extensions. This gave the functionality I needed in the tool and the size small size I needed. The added benefits to this approach are that they fit easily in the tool well under the rear seat, low cost ($40 total), instant availability (Home Depot, Sears, Lowe's, etc) and the utility of being able to drive the winch with a cordless drill.
Quick Reply: Spare Tire Crank Tool
