Transmission Problems!
Let me start by saying that I have the Gryphon and am waiting on my custom tunes. I have an 05 f150 with the 4.6. I was driving today and my truck shifted really hard twice. I took it back out later to see if I could pinpoint what was wrong with it and it began to completely drive funny. It started to rev up really high and would not drive any faster. I pulled over and in the dialogue box Trans Fault came up and the codes P2106 and P0720 came up as well. When I would put my truck in drive it would rev up really high for about 10 seconds before it would go anywhere and then once it would move it would go any faster than 20-30 MPH. I was only about 1 mile from home so I went on home very slowly. What is going on???
maybe your speed sensor, the rear sensor on the left side tranny, http://www.rockauto.com/catalog/moreinfo.php?pk=1189648
Thanks for the help Bob. I meant to repost on here and update everyone. I'm about 99% sure that my problem is not Gryphon related. I did a bunch of researching on multiple forums and websites and am pretty sure that my Output Shaft Speed Sensor has gone bad. Talked to our parts dealer today and the sensor is only $25 bucks so I told em to get it and it will be at our shop in the AM. I'll be sure to let everyone know if that fixes my problem.
I do have a question about the location of the sensor though. I crawled under my truck the other night to look at the location of the sensor and am pretty sure I found it. Isn't it the sensor right above where the o2 sensor runs over towards the tranny? I'm going to have our head mechanic look at it tomorrow and he should be able to tell but I'd like to be able to confirm it for him in the rare case that he's not sure.
And, you can eliminate the programmer as a cause by changing the tune back to stock and finding if the problem persists. I'm in your camp though, I doubt very much that the programmer is at fault.
- Jack
Anything can fail. I wonder about the condition of the electrical connection to the sensor. If that is poor, it would possibly generate the same symptoms.
- Jack
- Jack
Any way i can move this thread to the transmission section and retitle it?
Thanks Bluejay. Much obliged. Great news! The truck's running great!I stayed a little late last night and put my truck up in the air and dropped the tranny pan. After I got it dropped I decided to deal with it today. When i went in this morning, I looked at the magnet and it had a good deal of stuff on it and there was also a bit of very fine particles mixed in with the litle bit of remaining fluid in the pan.I looked at the filter and the inside was nearly black ! I decided to start cheap and called in a new filter kit and fluid. Put the filter in, Put the pan back on with the new gasket and bolted it back up. Let the truck down and got her filled up with fluid. Held my foot on the brake and went down through the gears, then back up, then down again, then back up one last time. Checked the fluid again and topped it off. Took it for a test drive and she ran like a charm ! Im still trying to figure out why the filter was so gunked up though. We use some of the BG products at our shop and when i dropped the pan about 7,500 miles ago I used a 2-can pack of tranny conditioner. My only guess is that stuff cleaned it really well and all the debris that it cleaned is what clogged up the filter. Any thoughts?
