Fffffed up big time need help
Old 07-12-2012, 12:12 AM
ShIzZaM_EsipOv's Avatar
Today I was trying to reinstall my power locks after fixing them and put together my door now I can't get in on that side I'm not sure I'm thinking that I put the lock pin wrong or something any suggestions and does anyone have a pic of a door handle that hasnt been touched so I can see how the pin goes
Old 07-12-2012, 12:30 AM
jethat's Avatar
There pretty awkward. I did mine but I'm not clear what your having a problem with. Did you remove the outside door handle? did you take them both apart? shouldnt have done that.. 1 at a time do you can use the other side to see how they go.. Kinda like drum brakes always do 1 side at a time. Dont have pics should have taken some when I did mine.. Good luck!
Old 07-12-2012, 12:32 AM
Alright yeah pretty Dumb of me idk im just gonna call it a day and try again tmmrw
Old 07-12-2012, 12:39 AM
maybe might have a picture on my old computer. I did a quick search on the forums didnt come up with anything earlier
Old 07-12-2012, 01:03 AM
Yeah hope u can find one I was checkin the Fourms couldn't find anything about the door handles if I can't find anything I'm gonna have to check out my local junkyard and take pics
Old 07-12-2012, 09:33 AM
from alldata, not sure if this is enough to help you
1 Remove the nuts.
2 If equipped disconnect the actuating rod from the lock cylinder.
3 Release the clip and remove the exterior front door handle rod.
4 Remove the exterior front door handle by pushing outward from the bottom.
Old 07-12-2012, 05:21 PM
Well I got it all put together now Luckly I have keyless entry I don't need my key to get in but I found out my exterior lock is broken it needs to be replaced or sent to a lock smith
Quick Reply: Fffffed up big time need help
