ABS Light just came on 1999 f-150 Why?
on
Like Dirty Harry famously said "Are you feeling lucky?"
on
If the rear ABS sensor is bad, it will light the ABS light BEFORE the vehicle moves. If the light comes on at 12 MPH on the first drive-off after start-up, it means the system failed its dynamic self-test. If it comes on intermittently and without pattern, it might be any one of a number of things.
Get the code read. A cheap OBDII scanner will not do the job. See the referenced thread in the previous post, it has more information in it.
