TCIL light
Old 09-01-2012, 06:43 PM
acasto's Avatar
TCIL light
I have searched on here and found a lot of good info on flashing tcil lights.
I put new tires all the way around on my 99 F150 screw 4x4, and on the way home from the tire shop, tcil started flashing.
Went from 245/75/16s to 285/75/16s.
Could this tire size change be the cause of the tcil flashing?
I plan to get the codes asap, but thought I would ask this question first.
Truck has 141000 miles on it. Only owned it for 4 weeks now.
Tony
Old 09-02-2012, 04:09 PM
acasto's Avatar
Hey, Tony.
I can help you with that. If you remove the negative side of your battery cable, it will reset the PCM and your truck will now operate without the TCIL light blinking.
It's a simple fix. Hope this helps.
Old 09-07-2012, 05:21 PM
BobFinnell's Avatar
Tire size does effect shift points. The ecm does know what size tires. Period. Good bye
Old 09-07-2012, 09:41 PM
Mark Kovalsky's Avatar
The PCM doesn't know what size tires are on the truck. Reprogramming the tire size is only to correct the speedometer and the odometer. It won't affect the shifting. Changing to larger tires can't make the TCIL blink. Disconnecting the battery will erase the code, but it won't fix what's wrong. The light will come on again if the problem is still there.
You need to take it to a shop that can read the codes. Most independent shops and all Ford dealers can do it. The auto parts stores that read codes free can't read Ford transmission codes. Don't go there.
Quick Reply: TCIL light
