04 F150 engine swap
Old 10-06-2012, 08:51 PM
Normusj1's Avatar
04 F150 engine swap
I have a 2004 F150 4x4 with the 5.4l 3v triton motor that needs replacing due to trusting a mechanic that said he could replace the plugs in it, and he wound up blowing my motor up. I was wondering if any other motor besides the triton motors will bolt up to the transmission in my truck. Am just considering all the possibilities before proceeding with spending the cash on a reman 5.4.
Old 10-06-2012, 10:24 PM
jethat's Avatar
No. No other motor is a practical swap.
Old 10-06-2012, 10:26 PM
jethat's Avatar
you could go used 08+ they change the plugs so they dont break and they also improved the cam phaser stuff.. See if you can find an 08-10
Old 10-06-2012, 10:36 PM
How did the mechanic "blow the motor up"? What's actually wrong with it now?
Old 10-07-2012, 07:50 AM
Normusj1's Avatar
Not exactly sure what he did, I do know that he took the heads off to get the plugs out. He also replaced the timing chains, guides and tensioners. Going on the info from the local ford dealer he didn't get the cams exactly right which caused multiple issues. The motor runs now, but the oil pressure is at 13 psi, and will not build any higher.
Old 10-07-2012, 09:33 AM
09+ is a hard swap. Someone did it and had a kit of issues. Late 08 with brown cop boots is the one side go for.
Old 10-07-2012, 10:41 AM
jethat's Avatar
This is a deal where you would have saved a ton of money basically an engine by having a ford mechanic work on your engine to late now but the plugs can be removed with special tools. Your guy obviously has no clue what he's doing..
Old 10-07-2012, 10:44 AM
Clueless. I'd take him to small claims court. Guess he never heard of the Lisle 65600 tool.
Old 10-07-2012, 10:45 AM
When are you going to turn off your autocorrect? At least look at it before you hit Send..........
Old 10-07-2012, 03:36 PM
Normusj1's Avatar
I am looking at what other engines will bolt up to the trans either new or older.... I am determining the best route to take. I will be doing all the work myself (cheaper), unless I go with having the local ford shop do it (much more expensive). The motor does not need to be a newer one I can go with pretty much any option right now, i.e. 351W, 302.....
Old 10-07-2012, 08:51 PM
jethat's Avatar
Its really not practical infact I've never seen anyone put an older engine in place of a modular. The most sensible thing is to get the samething you have and if your gonna do all that work get a better one then the one you took out..
Old 10-07-2012, 10:18 PM
Glen R's Avatar
Not sure what your budget is, you could take a look at the 5.0. they are currently available new with computer for around 7500.
Old 10-08-2012, 01:55 AM
The only engines with the same bell housing pattern are the modulars (4.6, 5.4, 6.8) and the new 5.0 and 6.2.
Old 06-27-2014, 07:52 PM
TySevrens's Avatar
Reviving this thread.. I've got my 04 5.4 triton just waiting to be blown to hell.. I've been thinking the same thing here.. just swap the motor out.
So in reading this thread I'm now wondering what my options are and I can't tell for sure what the right thing to do is..
Up to 08 is direct swap or no?
5.0L .. ? What years would work?
Thanks for any input.
Ty
Old 06-27-2014, 08:45 PM
jethat's Avatar
actually any 3v 5.4 is a direct swap. Period. in late 07 early 08 they changed to a one piece plug design and the newer motors have cam phaser fixes. the 3v 5.4 was available until 2010 or so.
Quick Reply: 04 F150 engine swap
