2002 Ford F150 Supercab dome light not working
Old 10-16-2012, 10:09 PM
OF150's Avatar
Unhappy 2002 Ford F150 Supercab dome light not working
My 2002 F150 dome light wont come on when doors open, neither does the top brake light work. what could be a problem? if a fuse could you tell me which one , lost my owners guide thanks
Old 10-17-2012, 10:54 PM
SSCULLY's Avatar
Do you have the dome lamp with the 3 position selector switch on it ?
- On - off - On with doors
Does the dome lamp come on when you rotate the panel dimmer all the way up ( past the indent click ) ?
Do you have a relay installed in the interior lamp relay slot in the cab fuse panel ?
did you try changing the bulb if the switch or panel dimmer don't work ?
Owners manual - Download a PDF of it :
https://www.fleet.ford.com/maintenan...ls/default.asp
when you say "neither does the top brake light work" is this the cargo lamp part or the CHMSL ( Center High Mount Stop Lamp ) ?
Old 10-18-2012, 09:05 PM
OF150's Avatar
Smile
it doesnt come on with the panel dimmer. and no its not the 3 selector type and ive tried a different relay and still no luck and yes its the high mount stop light. ive had the problem before on another truck (97 f150)and forgot what i did lol
Old 10-19-2012, 11:02 AM
Raptor05121's Avatar
I know the CHMSL is connected to the dome light somehow- I tore off the roof of a 10th Gen once and saw the wiring. I'd start at the switch and check for power there.
Old 10-19-2012, 05:23 PM
SSCULLY's Avatar
If it does not work with the door switch or the pannel dimmer switch, did you change the bulb ?
Maybe try checking the bulb connector with a meter to see if power is there ?
The CHMSL is not part of the interior lamps, the cargo lamps are, but not the CHMSL.
Quick Reply: 2002 Ford F150 Supercab dome light not working
