Motor won't turn over after swap starter won't crank
Old 10-21-2012, 08:35 PM
Wert01's Avatar
04 150 heritage 4.6
Just put a used motor in my truck and after everything was done it will not turn over the starter just clicks (brand new starter) had it tested to be sure and it's good I check the starter relay on the firewall and that also just clicks I checked and double checked everything could a ground stop the starter from turning the motor over there's a ground coming from my firewall and not sure where it goes I can't see it from the pics I took I am kinda of stump after 2 days of trying to figure this out I am not a mechanic I just couldn't afford 3 grand for someone to put a motor in my truck any help would be appreciated thanks
Old 10-21-2012, 08:40 PM
jbrew's Avatar
That's definitely a yes.
Old 10-21-2012, 09:42 PM
DYNOTECH's Avatar
Also make sure the engine is not locked up and turns over by hand.
Old 10-21-2012, 10:19 PM
jethat's Avatar
That should have happened long before it made its way into the engine compartment..
Old 10-21-2012, 10:54 PM
jbrew's Avatar
Wouldn't that suck lol.
Old 10-22-2012, 12:10 AM
Toyz's Avatar
Post a pic of the ground strap.
Old 10-22-2012, 12:20 AM
Wert01's Avatar
So the motor does turn by hand I chk long before I put motor in the ground strap is on passenger side firewall I will post pic in morning when I get to shop this ground is still not hook up but I connected it to one of the alternator bolts and there was no difference ( I don't even know if that could of been mused as a ground also my battery is good terminals are clean I read something that maybe the strap goes to the intake bolt ? Not sure ill post strap in morning thanks
Old 10-22-2012, 12:40 AM
jbrew's Avatar
3 grounds on the firewall over there. Starting at the firewall passenger side corner, you have a PCM ground. Second ground, next to the relay/solenoid is a larger battery ground, it's a direct battery to firewall ground. Third, -is a radio noise suppressor ground that runs either to the manifold;- or if the manifold is composite, that grounds @ the front of the engine.
Old 10-22-2012, 01:07 AM
Wert01's Avatar
Ok I will check that just so I know if one of theses grounds where not connected it would stop the starter from cranking the ground in question is right next to the relay for sure it's the only ground I remember taking off but not sure where it goes I will check in the morning thank you so the pic is in my profile I don't know John to get it on here please check it out I mounted that ground to the head and no difference
Old 10-22-2012, 11:49 AM
Wert01's Avatar
That pic is in my profile didn't know how to get it on here check pro for pic thanks
Old 10-22-2012, 12:44 PM
Toyz's Avatar
That is the engine to chassis ground. Should go to the intake manifold if it is aluminum.
Or better described as
I don't think that would effect the starter. Can you take a pic of how you have your starter harness hooked up? Maybe you have something crossed up there.
Old 10-22-2012, 02:43 PM
Wert01's Avatar
Took pic its in my profile check it out let me know thanks
Old 10-22-2012, 03:08 PM
Toyz's Avatar
That looks correct to me. There is a frame ground just up a bit from the starter. It is part of the starter harness. Grounds to the frame just inside the passenger fender. Is that ground hooked up? Let me see if I can find a pic of it.
I guess someone should ask since the starter is clicking... have you tested the battery? It happens a lot from sitting.. not sure how long it sat during the swap but the battery may be an issue.
Old 10-22-2012, 05:43 PM
Wert01's Avatar
That ground is good it just a bit up from the starter I took it off n cleaned it up battery is good has right voltage any other ideas ?
Old 10-23-2012, 01:27 PM
Wert01's Avatar
Hmm check the grounds they seem to be fine could it be a sensor or maybe the torque converter
Quick Reply: Motor won't turn over after swap starter won't crank
