2012 5.0L oil usage
Old 11-11-2012, 03:20 PM
Bucky34's Avatar
2012 5.0L oil usage
good afternoon,
I have 5000km on my new 2012 stx, I checked the oil the other day and noticed it's down a liter.
Anyone else have this problem? Is it common or should be seriously concerned?
Let know,
Bucky
Old 11-11-2012, 05:00 PM
How many miles on the engine and how many miles to use the litre? Mine uses almost a qt in 5000 miles.
Old 11-11-2012, 05:13 PM
Bucky34's Avatar
Hey Bluejay,
Thanks for the reply. It would work out to be the same usage as your truck.
Just seems weird to me that a vehicle with only 5000km on it uses oil.
Thanks again
Bucky
Old 11-11-2012, 05:20 PM
jbrew's Avatar
The newer they are, the more they use oil. Until fully broke in. Some use a little oil throughout. It's normal, well Ford has it normal to use 1 quart per 1000 miles or 1600 km's
Old 11-12-2012, 04:35 AM
code58's Avatar
Originally Posted by Bucky34
good afternoon,
Let know,
Bucky
How did you determine that it was down a liter? Most cars and trucks anymore aren't at the top mark when full. Some (mine included) have been about half way between the top and bottom mark when filled with the proper quantity of oil. The only way to know where the true "full" mark is, is to do your own oil change (I do) and fill it with the exact amount called for in the manual after a filter and oil change. Once run and let to drain down, that mark on the dip stick, on LEVEL ground, will be your full mark. Scribe your stick for the full mark. DON'T fill to top mark, if the prescribed amount doesn't bring it to there. Most manufacturers quit putting "full" and "low" on the sticks quite a few years ago and MOST don't come to the top mark when full.
Old 11-12-2012, 08:52 AM
That is good advice. Do an oil change and fill it with 8 qts. After it sits a while, check the level. That will be your full mark, and go from there.
I expect one to use a small amount of oil, I want it to do so. A quart in 5000 miles is very low usage. By using a small amount, it is less likely to be so tight that it wears out sooner.
Old 11-12-2012, 12:57 PM
MPETE's Avatar
agreed.
Ford says for approx the first 10k miles, the 5.0 will consume a little bit of oil. anything more 1qt/1k miles is considered excessive.
after 10k miles a consumption rate of 1qt/1500 miles is considered normal.
Old 11-12-2012, 03:28 PM
It has been my experience with 5.4 engines that they use a qt of oil in about 2500 miles until one I owned had about 80,000 miles on it. The other one used a qt in about 2500 miles until about 70,000 miles. After that many miles the oil consumption was a qt in about 5,000 - 6.000 miles. It takes a long time for the rings to fully seat.
I've had a similar experience with a 94 5.0 truck engine and a 200 cu. inch 81 Granada engine.
Also, full on my truck is at the 1/2 qt low level on the dip stick. If I add that extra 1/2 qt, it will disappear until it gets to the 1/2 qt low level.
Old 11-13-2012, 03:57 AM
code58's Avatar
Blue, did you mean to say 8 qts. or is that a mis-stroke? Maybe 6?
Old 11-13-2012, 09:05 AM
The 5.0 which I think he has calls for 7.7 qts. Everyone just puts in 8 if you are using cans. Who knows what each bulk user does.
Old 11-13-2012, 11:51 AM
Glen R's Avatar
I ran into a similar issue with Expedition. It ended up they were only putting 5 in during teh oil change instead of the 6 called for. This is based on teh quoted oil change price, with 5 qts oil. I now specifically tell them 6 qts, and they charge for one more.
Old 11-14-2012, 03:45 PM
Bucky34's Avatar
Thanks to everyone for the great information.
This site is an amazing way to really find out the info instead of dealing with the dealership.
Old 11-15-2012, 03:04 AM
code58's Avatar
Blue- you should know since you're '11 is also a 5.0L. I realize you probably don't change your own oil, I'm just amazed at that quantity since it seems like a lot of cars are dropping quantity, rather than increasing. Oil companies should like that.
Old 11-15-2012, 09:26 AM
Yep, I was surprised,after buying the truck, to discover that the smaller 5.0 took a quart more than my 5.4. May have something to do with it being a high RPM engine. I don't know.
Old 11-15-2012, 09:33 AM
One thing is for sure---with all the different quantities required for various engines, always check the level after an oil change. Twice, with my 5.4, I was shorted a quart and this was at a Ford dealer. The first time it happened, the service writer even argued with me that it only took 6 qts, when I went in and informed him it was a quart low. He the proceeded to look it up to prove to me and I got to point out the difference in a 2v and a 3v. I never drive off without pulling the dip stick. That will also eliminate the possibility of their forgetting to put the new oil in.
Quick Reply: 2012 5.0L oil usage
