overdrive light blinking
Old 05-01-2013, 02:06 PM
rjd's Avatar
rjd
rjd is offline
I have a 2002 4.6 l f150 xlt 4x4 today I was driving my truck car pooled wright out in front of me I had to hit the brakes really hard now the overdrive off on light is blinking what would cause that?
Thanks in advance ,Ralph
Old 05-01-2013, 02:32 PM
There is a button on the end of the shift lever, I think. Push it in and see if it turns off.
Old 05-01-2013, 02:49 PM
AndersonS's Avatar
If the overdrive light is blinking, then your transmission's overdrive isn't working for some reason.
Old 05-01-2013, 02:52 PM
Yes, the torque converter is locked, pushing the switch a time or two may release it.
Old 05-01-2013, 04:24 PM
rjd's Avatar
rjd
rjd is offline
Thanks I will try that
Old 05-01-2013, 05:17 PM
Bluegrass's Avatar
When you turn off the motor, the function automatically resets unless there is a trouble present.
If it comes back on, there is a code set.
Have it read and come back with the number.
Good luck.
Old 05-01-2013, 10:44 PM
Even if it resets itself, I'd go get the code read. The free scans at parts stores can't read Ford transmission codes, you need to take it to a shop that has a higher end scanner.
Old 05-04-2013, 01:16 PM
rjd's Avatar
rjd
rjd is offline
i brought to the service station replaced valve body ribbon which is a electronic part inside the transmission the priced to have fixed was $438.00
Quick Reply: overdrive light blinking
