Expedition / Navigator
2001 Expedition Tire Pressures
Old 10-09-2001, 02:36 PM
maim's Avatar
I was wondering if people are using the recommended tire pressure or what they have their tires set at. It suggests 30 psi for the front tires and 35psi for the back tires. I don't know what kind of differences it makes, but I have the front at 35 and the back at 35psi.
Old 10-09-2001, 05:33 PM
AlanM96SS's Avatar
I believe that the factory recommended tire pressures for these trucks are WAY underrated, hense the problem the the Explorer/Firstone war. Part of that problem, in my opinion, was the the factory recommended tire pressure for the Explorer was less than 30 psi. I believe that Ford underrates pressures to improve ride quality, but you lose handling quality with underinflated tires, that is on the road anyway, offroad is a whole other story. I believe that the tires were getting too hot and had tread separation. I will admit that if the tires were made better they would not have come apart under low pressures, but I also believe that Ford should have recommended higher tire pressures, but to get back to the point - cuz i know i dont want to get in the Ford/firestone war. I have the 17" wheels on my X and they say on the tire that the max pressure is 44 psi when cold. I keep 40 psi in all four corners. I have watched tread wear closely and have not noticed any uneven wear especially in the middle, where you would expect it from overinflation. The ride of the truck is not that much noticeable with the higher pressure. Well, hope i answered you question.
Old 10-09-2001, 07:45 PM
FamilyRide's Avatar
Mine with the GEnerals recommends 26psi. I usually run them at about 30-32. When towing I've run 32 and most recently 35.
No problems but I have noticed LESS wear when they are pumped up some. At 26-28 they are like rolling on marshmellows.
Old 10-09-2001, 08:05 PM
Dvds's Avatar
I run my 99 EB 4X4 with Michelin LTX M/S at 32 front, 35 rear. Still a comfortable ride at those pressures. The Michelins ride lots better than the original Firestone Wilderness. The Michelins were a gift from Ford.
Old 10-10-2001, 02:26 PM
maim's Avatar
Thanks for all of your replies they do answer the questions i had in mind.
Old 10-10-2001, 03:35 PM
dfwbmw's Avatar
I don't know what Discount Tire knows but when I got my Expy back from having the Navigator wheels put on they put 41 psi all the way around. The General tires say a max of 44 psi, door jam says 26 front and 33 rear. Anyhow, I put them back down to where I put them the day I drove it off the show room floor. I use 34 psi front and 36 psi rear. Little stiffer ride but it handles much better and you know they are not getting as hot. Also, no body will dispute the more tread life you get out of a slightly more inflated tire.
Old 10-16-2001, 09:33 PM
bjgl's Avatar
FWIW, I've got Kelly Safari AWR's on my 99 4X4 (LT 265's) and the cold pressure is 50 lbs. I've got it there with no ill effects. Still rides mushy.
Brian
Old 10-20-2001, 08:27 PM
frog's Avatar
Smile
30/35 around town, max pressure at 44 psi for highway trips.
Old 11-16-2001, 04:41 PM
BIGREDEXPY's Avatar
I have TOYO PROXES ST 286/60/17 and I run them at 35psi
I notice a difference between 30psi and 35psi. At 35psi the truck handles great and at 30psi on a turn I sometimes feel the rear slipping.
In the future I plan on getting some 20"s I think they run at 40-45psi.
Quick Reply: 2001 Expedition Tire Pressures
