smog/air pump elimination on 5.0L
Old 01-20-2002, 01:31 PM
inski21's Avatar
The air injection tube has rotted off my exhaust. So, I was thinking of eliminating the air pump all together. I have a Mustang eliminator pulley and bracket, but it doesn't look like it will fit.
Has anyone ever done this? Can I just remove it and get a shorter belt? Will the Mustang unit fit?
93 XLT 4x4 5.0L
Thanks for any help on this.
Old 01-27-2002, 12:18 PM
inski21's Avatar
Has anyone ever replaced thier air tubes that go to the exhaust? I think the diverter valve is chirping, is this common?
Old 01-29-2002, 09:21 AM
curt73@aol.com's Avatar
i don't see why the mustang pulley wont fit. it should be the same. the only thing different on the truck engine should be the heads. you can get a shorter belt. everyone does it with the mustangs.
Old 01-30-2002, 08:58 PM
inski21's Avatar
The Mustang pulley is smaller than the truck pulley. I've only held up and eye balled the bracket and it didn't look right. I guess I'll take a closer look as soon as this "winter" storm is past.
When people use shorter belts, do they just head to the parts store and try a few? I imagine the length changes quite a bit once an air pump or alternator is eliminated.
Old 01-30-2002, 09:31 PM
stf8b's Avatar
inski21:
Please keep us (me) udpated, as my smog pump just went, too. I want to do the same thing you do on a '95 and am deciding between trying to gut the pump and re-install and using a 'stang elimination pully (may require shorter belt). I won't be at it for a week or two, but any input/advice from your experience would be a huge help!
PS--do our smog pumps have any electrical connections? I don't think so, but I'm not totally sure.
Thanks, good luck.
-Scott
Old 01-30-2002, 11:10 PM
inski21's Avatar
I'll keep this topic updated.
I have had expirience with this before on my 86 Mustang Gt. I siezed the pump while cleaning engine components during a complete engine rebuild. I wussed out and just got a new one($90). A buddy I used to work with has a very hi-po 93 Stang 5.0L and used to use the eliminator pulley I currently have. He now has no air pump eliminator. He said he had to buy a mess of Ford serp belts until he got one that was right. I'd like to avoid buying a load of belts.
The Mustang pulley is smaller than the truck, but I might be able to swap the pullies. The bracket the pully is on is cast aluminum- but rugged-so I cant just weld something on if it doesn't fit just right.
I'll try to get serious this weekend or sooner.
Old 01-30-2002, 11:19 PM
inski21's Avatar
Not sure about the electrical connections. If the pump is gone there is alot of diverter tubes and valves and crap that can be canned. And I can finally plug that finger sized hole in my exhaust in between the 2 cats.
Old 01-31-2002, 01:10 AM
PKRWUD's Avatar
FWIW, your cats rely on getting air from your smog pump. If you remove your smog pump, you should remove your cats, too. If you don't, they won't get hot enough to do their job, and the end result will be them becoming clogged, blocking your exhaust. There really aren't any performance advantages to removing the smog pump. It's purely an appearance issue.
Take care,
-Chris
Old 01-31-2002, 01:27 AM
stf8b's Avatar
Yeah, I heard that about the cats. Would this still be a problem for aftermarket high-flow cats? For example, I didn't think that the bassani high-flow Y pipe w/cat had "pre-cats," heaters, whatever (designed to heat up the cat). Just curious, as they are going in relatively soon.
Oh yeah, I know you only gain 1/2 hp or so from removing/gutting the pump, I'm just after a solution that's cheaper than replacement--I don't want to buy a pump from the junkyard, and the dealer wants $250 (!). Are there other places to go for on OEM one?
later
scott
Old 01-31-2002, 01:39 AM
PKRWUD's Avatar
Hi flow cats won't suffer as quickly, but they will suffer. Your exhaust will end up being richer, and unburned fuel causes a reaction with the catalyst (sp?) in the cat, and causes it to melt together, clogging the exhaust. This is accelerated because with no pump, you're not supplying the extra air into the cat, which supplies oxygen, and thus raises the temp. Cats don't do squat below 750 degrees. So, the combination of a richer exhaust and cooler running cats eventually equal a clogged exhaust. If you elect to do this, you need to remove your EGR valve as well, because the EGR cools the combustion chamber, and eventually the exhaust. You will need to be running as hot as you can. If you are sold on removing your pump, I strongly suggest that you use an off road exhaust without any cats. It's much easier, and gives you less to worry about.
Take care,
-Chris
Old 01-31-2002, 02:20 PM
stf8b's Avatar
Gotcha. Thanks for the info. I think I could run a system without cats, as we have no emissions laws where I live, but I'm not totally sure about going sans cats. Looks like I might just shell out for a new pump. At least I know it'll bolt right on.
later
scott
Old 01-31-2002, 07:42 PM
FORD302GUY's Avatar
FYI -I bought a remanufactured smog pump with a lifetime warranty for 39.99 at a local parts store.
Old 01-31-2002, 08:34 PM
how do you know when your pump is gone?
Old 01-31-2002, 09:58 PM
stf8b's Avatar
I know mine is going b/c whenever it engages, it makes a god-awful sound. The pulley is not seizing, but the bearings sound like a banshee.
later
scott
Old 02-01-2002, 03:44 PM
inski21's Avatar
I paid $90 for my Mustang smog/air pump.
Yes, my plan is for shorty headers, 3" y-pipe, one gutted cat or hi-flow cat(2way,not 3way or air injected), then a 1 to 2 muffler w/ rear exit tails. And No pump. (aka offroad exhaust). State emission laws say I have to have a cat, whether it works or not isn't mentioned in the laws, hehehe
Or, if it is too big of a project I might just fix the tube that is broken.
Quick Reply: smog/air pump elimination on 5.0L
